1996 Ford Mustang Logo
Posted on Jun 08, 2009
1996 ford mustang convertible ac blows cold only from defroster
Does not blow out vents on side and center
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1600
Points
12
Does it still blow out the floor and defrost when you set the switch to those positions or does it alway blow out the defrost no matter what? If you can get air to blow out to the floor, then it sounds like you lost the switch that controls the airflow to the vents. If it only blows out the defrost, then you probably lost the vacuum to all of the switches. When the vacuum is lost, it will only blow out the defrost. Check the smallest line on the vacuum distribution block located in the corner near the brake master cyclinder. That line provides the vacuum to control the direction of airflow within the cabin.
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: 1996 ford mustang convertible ac blows cold only from defroster
Check the vaccum line at the vacuum distribution block (to the right of the brake master cylinder). It's the smallest vacuum hose.
2answers
2004 mustang gt. air does not blow from dash vents or defrost
Open hood , passenger side firewall area, look for a thin,black vacuum line, follow it and look for any breaks or bad connection to its vacuum source. repair as necessary.
1helpful
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
No heat from vents
Heater blows cold?
These will help.
Thanks.
2helpful
2answers
95 mustang Still tring to get air to blow out vents will only blow hot air out the defrost holes... no matter if i put it on vent or AC or heat its the same temp and it comes from the defrost holes Some...
check the vacuum lines in the selector switch. the baffles that switch from hot air and cool air are vacuum controlled and if the lines are detached or cracked the suction will not move the baffles.
4helpful
2answers
2helpful
Ford mustang 1996 AC blows only out of defroster on front window and down by fee but not out side and center vents
Check for a vacuum leak. Follow the black vacuum hose from the vacuum tree under the hood at the firewall to inside the car. It runs from the left side of the car near the brake booster to the right side near the accumulator.
3answers
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
3helpful
1998 Mustang - AC blows only through Defrost vents
You probably have a vacuum leak on the passenger side. its a small plastic hose some times they come unpluged from the engine. or brake.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
