Question about Ovens
I need a manual for a europa merano under bench oven
Model FF70PB028W
5 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: need user manual for Omega
you can go to this link and get the manual from contactin directly to the company or you can list your model number and i can try for you here is the link if you choose to do it yourself http://www.omegaappliances.com.au/Default.aspx
i think your best off going to the manufacture because they will give you one for free where as other places might charge you please remember to rank how this post helped in your appliance situation and if there are any futher questions i can answer for you please message me back have a great day
rickead1
Posted on Aug 22, 2010
SOURCE: We brought a nouveau display
Please email Mitre10 directly contact@web.mitre10.co.nz , we will try to find a manual for you. We will need the model number or SKU number.
regards Mitre 10 customer support.
Posted on Nov 30, 2010
muntejaya
  • 10421 Answers
SOURCE: Is there an online manual
Hi, Sorry I don't find any manual otn line of your equipment. Kindly contact your dealer to get the manual
Posted on Dec 20, 2010
SOURCE: Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Posted on Jan 23, 2011
What are the dimensions of the space required to install an Omega Europa 20-1 oven under a bench
installation dimensions are included on the brochure of the unit
the brochure will be available from a retailer or on line and those dimensions are what builders use to make the right sized opening
Sep 09, 2016 | Ovens
Where can I get a user manual for an Omega Europa 14-1 Oven?
Search the internet for:
Make + Model + the word "Manual"
Apr 29, 2016 | Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
We brought a nouveau display under bench oven from Mitre 10 Mega it came with out a manual, would like a copy of a seven function oven please
Nov 25, 2010 | Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Oct 03, 2009 | Ovens
Omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
I hope that all makes sense.
Apr 12, 2009 | Ovens
Broken hinge on Europa oven
try Ausralian Bakery and Pizza, Equipment Importers
122 Whitehorse Road, Blackburn, Victoria, Australia. 3130
Telephone: +61 3 9878 6900
Facsimile: +61 3 9878 6966
They import Europa equipment
Dec 04, 2008 | Creda Europa E010E Electric Single Oven
Ovens Logo
108 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
