Question about Jabra Bluetooth Headset - BT2070
Cant get my bluetooth type ote4 into paring mode?
Paring bluetooth
make sure that your jabra is in pairing mode then go to the bluetooth menu of your pc. select add device and wait until your computer finds the headset
May 11, 2013 | Radio Communications
Cant find bluetooth on my kenwood kdc-w3537
it is a button on the remote half way down the left side it has a small picture of a phone next to the button you have to press, and are they pared, good look
Apr 11, 2012 | Car Audio & Video
I got a GameOn bluetooth from asda but no instructions? can u help
Setting up the gameon Bluetooth headset is like configuring any other Bluetooth accessory with your game console.
Depending on the type of console you have you basically need to pair the device with your console.
In order to get the headset into paring mode you will need to hold down the button that turns it on for a longer period of time than is required to power it on. For example if you need to hold down the power button for 2 second for the headset to turn on you will now need to hold it down for 5 seconds or more for it to activate paring mode.
Once paring mode is active your game console should pick up the headset and ask you for a pass code in order to create a secure wireless connection between the game console and your headset.
The default passcode is 0000. This is the code you enter when the console asks you for the code.
Feb 28, 2011 | Video Game Consoles & Games
Cant connect my Jabra BCE OTE4 with my LG 8300 cell phone...help
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Aug 21, 2010 | Jabra Bluetooth Headset with Adjustable...
My bluetooth was connected to my phone and one
Start with your headset turned off. Then, press and hold the call button for 6 to 10 seconds, until the indicator light is steadily lit (it will flash as if it was being turned on, but don't release the button at that phase). It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 will appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
Hope you are able to sort your problems out.
Regards, Carlos
Jul 13, 2010 | Motorola Mobility H500 Wireless Headset
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola stereo bluethooth headphones
The G1 Doesnt support Bluetooth A2DP yet, meaning it cant stream music via Bluetooth. Yet !
Oct 27, 2008 | HTC G1
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Jabra Bluetooth Headset - BT2070 Logo
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
