Rca 42la55rs How do you manually turn on TV when remote is not working. Cannot find the standby button, anywhere on the TV as indicated in the Manual for TV.
  • 8 Answers
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
Posted on May 29, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
SOURCE: need codes for daenyx tv
need ikon tv cod
Posted on Mar 24, 2009
cpt100
  • 154 Answers
SOURCE: lost manual for rca rcr3273
Here is the link for 4 digit codes for rcr3273.
http://www.eliztech.com/remotes/rca-codes-4digit-v3.php
-James
Posted on Mar 30, 2009
Reprogram rca systemlimk 3 for toshiba
Manually turn on the TV. Find the three-digit code for your TV.
Press and hold the CODE SEARCH button until the INDICATOR LIGHT lights, then release the CODE SEARCH button.
Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
These are the proceedings. If you want more details check this link.
Dec 24, 2012 | RCA Universal Remote Control
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
Emerson model #lc200em8g wont program with rca model remote rcu600m
Hello
Codes for Emerson TV with RCA- RCU 600 are
..........004, 006, 012, 023
..........024, 025, 026, 027, 028, 029
..........030, 031, 032, 033, 034, 035
..........036, 037, 038, 039, 041, 042
..........043, 044, 046, 047, 123, 124
162, 171, 177, 179, 191, 196, 208
1. Manually turn on the TV.
Find the three digit code for your TV in
the code list below.
button.
3. Press and release the TV button (The
remain lit).
4. Enter the code using the Number
Buttons.
INDICATOR LIGHT will turn off. If the
code is not valid, the INDICATOR
LIGHT will blink. Check the code list
and repeat process.
5. Aim the remote at your TV and press
turn off.
Note: If your TV does not respond, try all the
codes for your brand. If the codes do not
work, or your brand is not listed, try the Code
Search method on page 16.
6. With your TV on, press CH+ (CHANNEL
UP) If the TV responds, no further
programming is required.
OK
Mar 22, 2011 | RCA 257003 Remote Control
I have a rca modle 20f420t modle lost remote so bought a sony unaversal one but i need the manufacturer codes and cant find them
Hello
I do not find code for RCA tv to Sony universal remote. Anyway I send you three digit codes for RCA herewith. Just try with entering these numbers. I'm not sure will it work or not.
RCA tv has been listed in Radioshak 6-in one Universal Remote Manual.
RCA Codes: 000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
SONY Codes: 002/ 006/ 071/ 128
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | RCA 20F420T 20" TV
Lost my manual - need tv codes - ge universal remote - tv to program is a rca xl100 remote
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
Jun 14, 2010 | GE JASRM24912 Remote Control
What is the code for philips tv using RCA universal remote control ??
just follow the steps below
2.Press and hold the CODE SEARCH button until the
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
Jun 14, 2010 | Televison & Video
RCA Universal Remote Programming Instructions RC800L-C 1239
if u do not have the code most universal remotes will allow you do it manually and you will have to follow these steps and insted of putting the code you can turn the tv on then press the on/off button on the remote till the tv shuts off then press enter
Aug 21, 2009 | Technics SA-EX140 Receiver
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Electro Med Services...
