Question about Dyson DC25 All Floors Bagless Upright Vacuum
Dc25 over heating
Over heating
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Tip
    Dyson DC25 - Removing and refitting the cleaner head
    To remove and refit the cleaner head of your Dyson DC25, please follow the simple steps shown in the video below. This procedure applies to all Dyson DC25 variants.<br /><br />For further help and advice please visit <a href="http://www.dyson.com/">www.dyson.com</a> and click on Support. <br /><br />Dyson Customer Service<br /><br /><utube src="S4mouxQ_udo&feature=related"><br />
    on Jun 22, 2011 | Dyson DC25 Vacuum
    Tip
    Dyson DC25 - Correcting a jammed wand
    If you're experiencing difficulty in removing the wand from your Dyson DC25, please follow the simple steps shown in the video below. This procedure applies to all Dyson DC25 variants.<br /><br />For further help and advice please visit <a href="http://www.dyson.com/">www.dyson.com</a> and click on Support. <br /><br />Dyson Customer Service<br /><br /><utube src="XZ_MszGt2yQ&feature=relmfu"><br />
    What to do if I have a over heating motor
    The ball is jammed because the spring inside which holds the filter has become stretched. Open the Door on the ball and squash the button on the filter down. Then refit filter. Refit window on ball
    Aug 04, 2014 | Dyson DC25 All Floors Bagless Upright...
    Tip
    Dyson DC25 - How to wash the filters
    To wash the pre and post-motor filters in your Dyson DC25, please follow the simple steps shown in the video below. This procedure applies to all Dyson DC25 variants.
    The filters should be washed every 3-6 months using cold water. Always ensure the filters are totally dry before refitting them - this may take up to 24 hours.
    For further help and advice please visit www.dyson.com and click on Support.
    Tip
    Dyson DC25 - Correcting a misaligned pedal
    If you're experiencing difficulty in standing your Dyson DC25 in the upright position, please follow the simple steps demonstrated in the video below. This procedure applies to all Dyson DC25 variants.
    on Jun 20, 2011 | Dyson DC25 Vacuum
    Remove blockages dyson
    Hi there, it's Jack at Dyson.
    To remove any blockages from your DC25, our online Support page will walk you through each step to make sure nothing is missed: http://www.dyson.co.uk/support/dc25/dc25-irsvsye/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
    DC25 has two washable filters, and these should both be washed at least once every three months as shown in the video below. Use cold water without detergent, and allow at least 24 hours for both filters to dry completely before replacing them.
    I hope this helps, but if you'd like any additional information you can reach our experts in person by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Aug 02, 2014 | Dyson DC25 Vacuum
    My extension handle will not come out
    Hi Brenda,
    I am sorry to hear you are having difficulty with your wand handle/extension. Based on the details you provided, it sounds like you are describing the DC25. If you do own the DC25 please visit the links below for detailed instructions on how to resolve this.
    US Support:
    http://www.dyson.com/support/help.asp?article=1519&product=DC25-ALLFLOORS
    UK Support:
    http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/jammed-wand-video
    If your machine is the DC24, please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK) so we can provide further assistance.
    Best wishes,
    Jessica
    Jun 24, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Cant find reset button on my dyson dc25
    To reset your DC25, please follow the link below to view our support video guide:
    https://www.youtube.com/watch?v=q--faamcC7g
    Please note, the brush bar will never rotate when the machine is standing upright. Make sure you recline your DC25 into the normal vacuuming position before you test it.
    Hopefully this answers your question, but if you need any further assistance, please get in touch with our Helpline by calling free on 0800 298 0298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Online Customer Support
    Nov 02, 2011 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 All Floors Bagless Upright Vacuum Logo
    12 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
