Question about Farenheit Car Audio & Video
Bad disc when we put in a dvd, it says "bad disc"
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
Disc error
It means either the optical pickup trying to read the disc is dirty or bad.
If bad--it may not be cost effective to repair that unit.
Apr 03, 2012 | Vizio VBR100 Blu-ray/HD DVD Player
My DVD player willnot play commercial disc. It says no disc,bad disc,or no disc found. It is rejecting every disc I put in.
It is possible that the optical lens on you dvd player is dirty or worse it has gone bad. There are discs that are made to clean the lens. Here is an example : http://amzn.to/8Y4qSe
Mar 04, 2011 | GoVideo Televison & Video
Every disc is a "Bad Disc".
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Recoton Advent Advent DVD-8200 DVD Player
Govideo dvd player tells me all my discs are now "bad discs"
Open the dvd player up take a Q-tip dip it in alcohol clean the lenses . Then dry it off with a new dry Q-tip, put it back together start watching dvd's, Peter
Mar 12, 2009 | GoVideo Go Video DVD/VCR Combo
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
Any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
Feb 09, 2009 | Conia DVD8500 DVD Player
Sanyo DVW 7200 Disc Error
check to see if the disc spins......As in place the disc in the DVD player with the label in a position that is readable to you....Put the disc in close the tray and wait a few seconds. Open the tray and se if the disc actualy has moved. If it hasent then the motor is bad and not worth replacing!
Jul 07, 2008 | Sanyo DVW-7200 DVD/VCR
BAD DISC
Your laser eye is dirty or out of alignment. If you know how to clean it then do it, if not buy a cleaning kit for around $20. If that wouldn't fix it then have someone who know re-align it. Goodluck.
Mar 04, 2008 | Boss DVD-4200B Car DVD Player
Car Audio & Video Logo
16 people viewed this question
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
