Question about ASUS Transformers Pad Infinity TF700TWIFI 64GB, 1 Yr Int. Warranty
TF700 WON'T TURN ON
WON'T BOOT UP
There are a couple things to try.
Possible Problem: The tablet may have gone to sleep and a newly installed app or update is preventing the tablet from coming out of hibernation.
Solution: The tablet likely needs to re-start.
The trick is to know whether your tablet is in hibernation (actually running but not screen is turned off) or if it is actually turned off.
Scenario 1, tablet is on but is in hibernation mode
1. Press and hold the power button until you feel the vibrate. Then release. Wait 3 minutes (to make sure the tablet shuts down). After the 3 minutes go to scenario 2
Scenario 2, tablet is turned off.
1. Press and hold the power button. Keep pressing even after you feel the vibration (for about 30 seconds).
Other possible solutions:
If that does not work, then ...
2. Disconnect the tablet from the keyboard and press and hold (same as step 1 scenario 2).
3. If the others methods do not work, connect the tablet to a PC (with internet connection). Leave the tablet connected for a minimum of 30 minutes, but upto 2 hours. With the tablet connected to the PC, press and hold the power button (same as step 1 scenario 2).
If none of those worked, connect the tablet to a TV or monitor using the HDMI connection. If the TV/monitor displays the tablet, then use the display on the TV to reset to factory defaults and force a re-boot. While it is shutting down, disconnect from the TV.
If that does not work, check the user manual for how to reset the tablet to factory default settings.
Last but not least, contact Asus support because you might have to send it for service. But I suspect scenario 1 will work for you.
Posted on Feb 18, 2014
My tablet keep come on and off
If the tablet power off by itself suddenly, it might be the hardware issue already.
Please send to the service centre if it is under warranty.
Jul 01, 2014 | ASUS 32GB Transformer Pad Infinity TF700...
How to restart steps in starting up newinfinity tablet
Asus tech support phone number: 1 (812) 282-2787 or you can do a live chat: ASUS Service North America Just pick your product and you can chat with Asus.
Jun 24, 2014 | ASUS 32GB Transformer Pad Infinity TF700...
My brand new asus transformer pad tf700 will not charge just flash twice
I had this problem, then I disconnected the two black plastic parts of the plug, and there were two steel pins in there, I thought they were leaning in a bit, so I just bent them away from each other, put it all back together and my charger has worked fine ever since.
Sep 19, 2013 | ASUS 32GB Transformer Pad Infinity TF700...
Turns won boot
i need the make and model have you left it a long time it could be the battery flat needs replacing or problem with switch more info would help thanks
Aug 28, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Hipstreet titan android tablet
Try to boot to fastboot and REflash a stock firmware.
Jul 02, 2013 | Tablets & eReaders
My zeepad won't boot up
I'm having the same problem I've tried everything and nothing's working please help
Feb 20, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
ASUS Transformers Pad Infinity TF700TWIFI 64GB, 1 Yr Int. Warranty Logo
759 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
