Question about Panasonic Lumix DMC-ZS3 Digital Camera
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
After I take photos, there are black spots on the pictures in the same place each time.
  • Judy Jordan
    Judy Jordan Apr 22, 2014
    I have the same problem with mine too. The DMC-ZS8
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Posted on Feb 12, 2014
kakee
  • 1269 Answers
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Posted on Sep 16, 2008
  • 155 Answers
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Posted on Feb 09, 2009
Obertelli
  • 3006 Answers
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Posted on Nov 28, 2009
  • 11967 Answers
SOURCE: how to clean a panasonic lumix dmc ts1 lens
If the spots appear on flash pics only and are in different places on each photo, then the spots are not on your lens. Those are dust particles reflecting the light from your flash. It's a common problem with point-and-shoot cameras.
Posted on Mar 31, 2010
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
Set date stamp on Lumix DMC z58
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 07, 2014 | Panasonic Lumix DMC-ZS8 14.1 Megapixel...
Tip
After reading SteveGorak's experience, I placed the vacuum end of my...
Hello
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
Andrea
on Sep 06, 2011 | Cameras
How do I get the date/timestamp to display on pictures with Panasonic Lumix DMC-ZS8?
Jan 30, 2013 | Panasonic Lumix DMC-ZS8 14.1 Megapixel...
How do I clean the lens of lumix dmc fh25
Are you "serious" to offer me to clean up every photo in photoshop?
How come Panasonic does not guarantee their own product?
I have had many cameras in my life and this is a first one with this type of problem. My friend bought the same type just one step better ZS8 at the same time and he is facing the same problem as well, within one year just past the warranty like me. Is it really a water spot? It is getting smaller, when I zoom in and it is moving to the side while I'm zooming in. Is it on the sensor or is it on the lens? Is there any Panasonic reply to this problem?
Sep 03, 2012 | Panasonic Lumix DMC-FH25 / DMC-FS35...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
How do i transfer pictures from a Panasonic DMC-ZS8 to my laptop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 25, 2012 | Panasonic Lumix Dmc-zs8 14.1 Mp Silver...
My Panisonic Lumix was dropped in the lake in its case last summer. I dried it out and it still works great. The only thing is now when I take photos of things that are dark like night time photos or a...
If these spots are in different places on each picture, then they are actually reflections of dust particles in the air from the flash being so close to the lens. If they are in the same place on each picture, then they are indeed water spots on the lens.
Mar 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
How to clean a panasonic lumix dmc ts1 lens. i get spots when i take pictures
Mar 31, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
Panasonic lumix dmc-fx01
If the dark spot is not focused, it could be on the sensor. Otherwise, check the lens for any dust particles. If you can't find any dust, take the camera to an authorized service center.
Aug 20, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
285 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
