Question about Canon FAXPHONE L170 Plain Paper Laser
How to clean the gears on Canon PC310 Copier - Canon FAXPHONE L170 Plain Paper Laser
How do i fix the problem that the error code E000007-0000 for canon ir 3300 copier, fixing film has been changed with the new one, still the same error code repeated.
plz open the fornt part of fixing motor gear box and chek the rotetaion gear of white two step gear..if ur not undastand call me on 09989086587
Jun 07, 2015 | Canon Ir 3300 B/w Copier image Runner...
E000990 0000
has to do with the waste toner gate, PS12, gear set attached to locking handle on process assembly. PS12 is remaining blocked. Check the gear mesh, with handle down, the sensor should be open.
or is dirty with toner, clean
Aug 01, 2014 | Canon Gpr23 Irc2880/2880i Black Copier...
This is Canon PC310 personal copier. When it starts, it's making some noise sounding like paper grinding a bit, and orange light blink for about 5 seconds, and power itself is down. So it does nothing now....
Hello sunny,
I'm not being rude or critical, but with the limited information I've been given I can merely give a "best guess". The "rustling of paper" sound or "grinding of paper" sound is probably the fixing assembly. The fixing assembly uses heat and pressure to bond the toner to the paper. Without going into more details than necessary the fixing assembly can both make that sound AND because of the extreme temperature it uses, any malfunction will cause the copier to turn off for your safety. Fire is not good ! I just made a quick surf across the web. You did not pay as much for the copier as it will cost to have it fixed. You bought a GOOD personal copier from a GOOD company. But all things have a lifespan. I'm just giving you my honest opinion. And I could be wrong.It won't be the first time somone spent 23 years in a career and still was a fool. I wish you well. SPINAL
Feb 15, 2011 | Canon Office Equipment & Supplies
E017
From what I remember about this copier.... That code has to do with the Main Drive Motor. The solution was to replaced the two plastic gears that drive the fuser or clean the shafts. The main motor is in the front of the copier above the fuser. The 2 gears are on the fuser unit when you have it out, it could also be a ball bearing is not turning.... Good Luck
Aug 29, 2010 | Canon imageRUNNER 400S Copier
We have a code of systems error E000
Clean and check the fuser components,(heater lamp,thernistors and thermofuses).Clean the gears use WD 40.
Dec 28, 2009 | Canon ImageClass D880 Copier
How to clean my canon ir5000 and how to keep it save from dust.
if paper jam before fixing check fixing gears, if paper jam in the middle of copier then check sepration carona and drum finger.
Jun 14, 2009 | Canon imageRUNNER 5000 Copier
Gear grinding noise when copier operating
wouldn't be surprised if it turns out to be a toner cartridge. Have you had to replace it sine the noise began? Is it remanufactured / compatible? I won't be surprised if the grinding stops once it's replaced. Just my 2 cents.
Jun 13, 2009 | Canon PC-940 Black and White Copier
E210
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Feb 05, 2008 | Canon NP 6551 Black and White Copier
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Canon FAXPHONE L170 Plain Paper Laser Logo
12 people viewed this question
old marine
old marine
