Question about Whirlpool Refrigerators
Cooling off light
We have a model gz25fsrxyy7 that the cooling off light is displayed the lights are on in the refrig however its not running
HVACRH20
  • 237 Answers
SOURCE: Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section. http://tinyurl.com/3533ao
Posted on Jan 28, 2007
SOURCE: Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Posted on May 06, 2008
  • 10 Answers
SOURCE: Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Posted on Jan 26, 2009
mark_37388
  • 100 Answers
SOURCE: refrig runs but does not coll
First Check the back wall of the freezer to see if you see frost building up or try to see if you can fill air going into the ref with the freezer door closed if not try opening the door if you fill it now then you have a defrost problem. IF you do not fill air either way it is either the damper door is not opening or the fan is not running
Posted on Mar 30, 2009
  • 11 Answers
SOURCE: Older refrig/freezer. Compressor not running. Light working. Not cycling.
I think need t change the compressor
Posted on May 12, 2009
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Refrig is not cooling at all. thermostat controller light shows two lights on the frezer side of the display, 5 and 6. the refrig display shows nothing and i can't change it. please help
ok,do as i say
Keep your hands on the side panel of your refridgerator and see whether its hot,if its not its due to low gas ,fill it up with the help of some skilled persons
Mar 28, 2012 | LG Refrigerators
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
Side by side sub zero refrigerator: freezer is
still not clear. in your question you say refrig side is dark and not running, then you say you put a temp guage in it overnight and it's steady. So you DO have cooling in refrig? If it's just the lights, yes it could the switch or it could be the light bulbs.
Jul 16, 2010 | Sub-Zero Refrigerators
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Refrigerators Logo
14 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
