Question about Coby Televison & Video
COBY 32" tv volume is screwed up.
When i'm watching my cable on the AV source the volume doesn't start until 4, and then it's instantly kinda loud. So basically it's like. . . 1 nothing, 2 nothing, 3 nothing, 4 loud as hell. Just now i'm watching a video off my flash drive and the number 1 setting is blaring loud. I tried to find a firmware update but can't find one, and none of the sound setting changes anything. The model number is TFDVD3295
5 Suggested Answers
  • 1738 Answers
SOURCE: Buzzing sound when using HDTV input on
It is your cable box, contact your cable company.
Posted on Dec 29, 2009
SOURCE: mode/source set to TV on
Did you solve this? I have the same problem but mine stops on Ch 18.
Posted on Mar 05, 2011
bshldn
  • 736 Answers
SOURCE: Does anyone got a problem with his Sharp Aquos
Try an INIT over the phone with an aquos advantage advisor. You'll call 877-332-7867 get a case file created and be walked through the steps with an advisor. You are going to have to be able to press down panel buttons and plug in the television at the same time so you might need another person with you.
Posted on Jul 13, 2011
  • 45144 Answers
SOURCE: Coby 32" Television, Volume is messed up.
Coby is apparently out of business.
Posted on Feb 12, 2014
32" samsung hdtv flat panel: switches when you don't want it from tv to av/pc or av to tv/pc.
Sometimes, TVs will switch to a new input when they sense a new signal on the new input. So if you're watching TV and someone turns on the AV device (or makes a change that alters or starts a video signal), the TV may switch over to that signal. This is a function of the TV. Some TVs allow you to disable this function, others do not. I looked in the manual and didn't notice where this could be enabled or disabled. If you want to only watch one source, make sure the other sources are turned off.
May 14, 2014 | Samsung LN32A330 32 in. LCD TV
Volume for my COBY 32" Television is out to whack.
Your volume control/circuits are fubar. Coby is outta business so getting parts for it might prove next to impossible.
Jul 20, 2017 | Coby Televison & Video
Feb 12, 2014 | Televison & Video
Audio Cuts out on Streaming Video
I put the tv on av to watch a dvd. I now want to watch tv and it will not change from av to tv. I have a universal remote and it does not register of when I put it on tv it goes back to av
Feb 10, 2014 | Televison & Video
I can't program my direct tv remote to my coby TFTV3225 TV. Don't have the right codes. Does anyone know the codes?
11531 is the code given by DirecTV for this model. To enter this code . . .
1. Slide the mode switch at the top of the remote to the TV position
2. Hold both the MUTE and SELECT buttons until the LED blinks twice
3. Enter the 5-digit code 11531
4. Test the volume and power buttons for correct operation with the TV
If the code does not work first time, try entering the code a couple more times. If it still doesn't work, also try code 11436. DirecTV do not list any other codes for your TV, so if they don't work, it's possible that the remote will not work with your TV. There is also a code search option which tries every code in the remote. If this doesn't work, the remote definitely will not work with your TV.
Please try the codes above and let me know if you need further assistance or the code search instructions. Also, remember to slide the mode switch back to the DirecTV position after you have finished entering the codes.
Regards,
BElectric
Apr 24, 2011 | Coby TFTV3225 32 in. LCD TV
Can't control TV volume after installing Coby DVD765
Unfortunately that is how this unit is designed, you cannot adjust the volume while inputting from an external source, normally the subwoofer would have an AUDIO control, but this one has no knobs, the VOL +/ VOL- on DVD remote only controls while watching a DVD. Only work around for this is if your TV has a 3.5MM headphone jack, you can get a 3.5mm to RCA cable and then your television would be able to control the volume.
May 04, 2010 | Coby DVD765 Theater System
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
DVD picture is crystal clear, but wavy lines when using cable. Connected a different tv to same cable and picture is fine. internal coby tv to cable connection must be bad?
you can get a standard RF (cable) male connector to AV (the yellow,white and red colored) adapter at radio shack for a few bucks...if it is a internal connection, that will bypass it...you will just be watching cable on AV-1 or wherever you plug it in
Aug 28, 2009 | Coby Televison & Video
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
Televison & Video Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
