Question about Pool & Spa
Bestway Lay-Z-Spa After only 2 weeks of setting up my lazy spa item # B54123 my pump unit began leaking. It wasn't a problem with any connections or hoses, it seemed to be coming out of the base of the unit. I spoke to representatives about receiving a replacement and after about 5 weeks and repeatedly having problems getting a tracking number it arrived. I was told I wouldn't need to return the faulty unit and my replacement finally arrived today. My problem is I believe I received the inflatable unit and not the pump and filter system. I don't want to be responsible for a customer service error and go through even more hassle. Can you tell me the contents of the box unit #B54123N-14?
  • 717 Answers
We sell the Bestway Lazy-Spa however we do not sell anything other than the replacement filter so I cannot tell you what is all included with that part number.
I would suggest you contact the store you purchased the spa from to determine the contents of the replacement item.
Rod
US Parts Center
Posted on Apr 08, 2014
4 Suggested Answers
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
  • 111 Answers
SOURCE: leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Posted on Jul 27, 2012
SOURCE: laz y spa pump showing e02
our lay-z-spa was showing the e02 and not working so we checked on here and found some great ideas and went off to try them. as we was putting the pump unit back together we noticed that pipe B was flat !!!! so we rounded the pipe and slightly raised the pump unit and turned it all back on and it is now working fine so we thought we would metion it on here x
Posted on Sep 15, 2012
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
Has anyone had problems with Lay Z Spa pumps?
Lots of people have had issues with them. I'm afraid that they don't last particularly long. The Lay Z Spa's are built to a price.
I have delivered a new acrylic spa to someone today who previously had a Lay Z Spa, he had owned it for about 14 months and was already on his second pump unit.
Apr 22, 2017 | Pool & Spa
I have a lazy spa pump which seems to be leaking from inside. Have looked and cannot see anything obvious. Any ideas please?
most of the time it's the mechanical shaft seal that leaks do to age or damage might be a tuff fix on this pump
Aug 02, 2013 | Intex BESTWAYS 12X30 FAST SET POOL
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Leaking lay z spa pump
Jul 25, 2012 | Pool & Spa
Timer on chlorinator will not go on after 24 hours
The 24 hour timer is probably faulty and needs to be replaced.
Jun 04, 2012 | Bestway Usa Type 2 or II Bestway...
My bestway lay z spa pump and heater unit has stopped working. Three lines flash on the LED panel and all the lights are flashing simultaneously. Non of the buttons work and I have tried re-setting the...
PDF Manual at the link below.
http://www.drinkstuff.com/products/pdf/lay-z-spa-owers-manual.pdf
All lights flashing indicate a fault with the pump.
This is a common fault with these units which the supplier blames on people not following the installation and maintenance instructions.
If you require any further assistance then please just ask.
Aug 01, 2011 | Kitchen Ranges
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
Pool & Spa Logo
135 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
