Question about Bikemaster 1986-1988 Yamaha Yfm225 Moto-4 Atv Deep Cycle Trugel Battery
Bought a 1988 yamaha 4-225 seller said put in new batt and we had to jump it to start but it ran fine and started again but when we got it home it wouldnt start so we jumped it but put the cables on w
Cant find fuse box or any fuse do you have a solution for this problem
    Sergeant:
  • 320 Answers
If you allways have to jumpstart, then that battery is bad OR the charging system doesn't work.
To check the charging system: Run the engine.
After a few minutes, with the jumpstart cables removed, mesure the voltage over the battery. It should be between 12.8 and 14.3 volts.
If below 12.8 volts, the charging circuit is faultly. If over 14.3volts, it will cook and thus destroy your battery.
If that seems correct, disconnect the battery and have it loaded with a battery charger. Never charge faster than 10% of the battery capacity ( For an 18Ah battery, load at maximum 1.8Amps. Never load above 14.8volts )
Leave the battery disconnected for a day or 3 and test starting thereafter. If it goes, there is a current consumption in the atv. If it won't work, the battery is bad.
Posted on Mar 08, 2015
I just replaced battery and alternater but the battery died hile driving and once i jump the car it ill run for thirty seconds then die.
you've had the misfortune of getting a bad rebuilt alternator-sorry-they should give you another one -I hope its not hard to replace-Denny
Nov 05, 2013 | 2004 Chevrolet Impala
Turn key, no start, dash dead, but intermittent symptons
First I would look for voltage drop of both end of battery terminal.not a look or seem tight . you have to do it (voltage drop) and terminal at alternator.
now does alternator charging. take voltage of battery
if the problem occur have voltage of battery taken
like I read your problem it looks like wiring terminal ground and positive
the noise you hear is probably low voltage to a relay and the dropping voltage make the relay switch inside relay cycling noise click or buzz
Oct 05, 2013 | Chevrolet Cavalier Cars & Trucks
Hi, I own a 2005 R1 for a year now and about 2 or 3 months ago I felt that the battery maybe low, I tried to cherge it but it didn't help much. I bought a new battery today and after installing it the...
ur alternator or voltage regulator has issues-batt is not being charged--havum tested with a multimeter--inspect wiring 1st-may be loose or corroded
Sep 14, 2010 | 2007 Yamaha YZF-R1
98' Cav.. Drove it to store, shopped, didnt leave anything running or turned on. Went to car, opened dr...no dome light (thought, hmph, must have burned out -- fix later). Tried to start car... I turned...
this sound to me like at first I thought it was a fuse, as the problem went on it shifted more toward a weak cell in the battery, if a weak cell sits for a little while the battery will not hold the charge in that cell and that will cause loss of power, "its charge", in tne other cells. you had mentioned you used another battery and it ran great but when the battery was removed, things went wrong. You may check to see if there is water in your battery
Aug 19, 2010 | 1998 Chevrolet Cavalier
Truck won't start
click and no turn over is the starting system. battery, starter and solenoid, ignition switch. if batt is fully charged, check that cables are clean and tight. loose cables can start the vehicle sometimes and not others.
Feb 18, 2010 | 2000 Ford F250 Super Duty Crew Cabs
2007 Hyundai Elantra has to be jump started. Battery is fine
from your comment,theres 3 things that can cause this,loose batt.post connection,weak batt.or something in elect. circuit that stays on after car is off and drains batt.,like underhood light,dome or truck light,what u can do is when u park car unhook batt. cable,make sure batt. is well charged,hook it up next day if car starts,its something that drains batt.in car! if it doesnt start,batt. needs replacing.i ruled out starter,dealer should have checked it to see if it was pulling too much amps,and that its easy to jump.
Mar 29, 2009 | 2007 Hyundai Elantra Limited Sedan
Has hard time starting
sounds like the starter has gone out. when tey go bad the will put a draw on the battery
Feb 03, 2009 | 1997 Oldsmobile Achieva
Bikemaster 1986-1988 Yamaha Yfm225 Moto-4 Atv Deep Cycle Trugel Battery Logo
241 people viewed this question
Top Bikemaster Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Bikemaster Boating Expert? Answer questions, earn points and help others
