Question about Dirt Devil KONE Hand Vacuum MO213BLU Vacuum
Kone vacuum won't charge - Dirt Devil KONE Hand Vacuum MO213BLU Vacuum
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
Hello I Have a Dirt DEVIL KONE Champagne in Color. Not the Kurve But the KONE. It was Working Fine The other day, But Is now NOT Powering On When I Try to Turn The Switch on at the Top. The Indicator...
Hi Ross, sorry for this delay, but the email does not seem to be working, I will get on this as soon as I can and will efinatly have something for you shortly, been one of those days and I am not catching up yet.
Dec 07, 2011 | Dirt Devil Kone Vacuum- Blue Vacuum
The battery won't hold a charge, is there a fix or is it replaceable?
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Filter issue
look in the instruction manuel
May 03, 2009 | Dirt Devil Kone Vacuum- Blue Vacuum
How do i open my dirt devil kone to empty it?
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
I can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
Dirt Devil KONE Hand Vacuum MO213BLU Vacuum Logo
104 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
