Question about Sony Audio Players & Recorders
Stk-k840p el fusible esta bien pero no activa los relay
  • 11 Answers
SOURCE: Los cristales delas puertas no suben ni bajan en
chekear todos los cables primero y despues verificar todos los fusibles que esten buenos
Posted on Dec 01, 2009
SOURCE: como desbloqueo mi internet inalambrica
www.fixya.com/support/t5448730-cinedash_media_console
Posted on Aug 02, 2010
wd4ity
  • 4565 Answers
SOURCE: Tengo una harley sporters modelo l999.El motor
Ok, if my translation is correct, you have a '99 Sportster that shuts down and will not restart. have you checked for a spark at the plugs? Do not pull the spark plugs out of the heads to do this test but rather put another set in the plug wires. The Big Twins have a compression sensor on them and will not spark if there is no compression.
Is there power to the coil? You should show battery voltage to one side of the coil when the switch is on. If you do there is no spark, your cam position sensor in the timer cavity on the right side engine case may be bad.
Test the coil by disconnecting the pink wire. connect a jumper wire to this side of the coil. Turn on the ignition switch and make sure you have battery voltage on the white/black wire of the coil. MOMENTARILY ground the jumper wire and then take it loose from gound. Watch the spark plugs to see if they spark. If the do, the coil is good. You complete ignition system is in the timer cavity on the right side of the engine. I do not know of any way to test the unit. Sorry.
Good Luck
Steve
Posted on Aug 23, 2010
  • 713 Answers
SOURCE: El ups que tengo, no enciende y la bateria no esta
your port went bad unplug it and put it in another port.
Posted on Feb 22, 2011
  • 18 Answers
SOURCE: tengo un 98 pontiac sunfire nadie le a encontrado
lo que tienes que cambiar es las bujias y los cables otra ves y asegurarte que esten bien apretadas las bujias y los cables oh otra cosa puede ser que tenga una fuga de gas en los cilindro pero asegurate que las bujias sean compatibles para esa marca
Posted on Apr 16, 2011
Cual fusible le cambio para q encienda donde marca las millas
HOla amigo(a) no c a que te refieres con cambiar fusible pero te aseguro que si checas los fusibles. la taba donde esta el croquis de los fusibles hay unos que dicen algo asi como TBC o TBL o el de : ACC tambien
checa que esten buenos y tambien checa en el croquis que todos los tenga y que los tenga buenos! espero te ayude, suerte!
Jun 30, 2011 | 2002 Buick Century
Hola tengo un freestar 2004 de repente se prende es foco de la caja de velocidades que puedo hacer gracias
hola tengo una free star 2006 y paso el swiche y no hace nada .prende el tablero y todo el equipo pero paso la llave y nada
Apr 30, 2011 | 2004 Ford Freestar
Tengo un 98 pontiac sunfire nadie le a encontrado el problema lo e yevado con 4 mecanicos y no le encuentran el problema es ke en los cables delas bujias aveses esta a ventando corriente y aveses no...
Apr 16, 2011 | 1997 Pontiac Sunfire
I need a fuse diagram for a mitsubishi mirage. the one in the manual is totally different from the one in the car.
Ok is any body out thier speaks spanish that can help me with this problem please.Ok yo tengo un Mitsubishi Mirage 1.8 del 1999 y ahora mismo la boma no kiera funcional como manda,se supone que cuando yo le de al swith con la llave la bomba active por pal de segundo y despues tumbe.Pero no lo esta asiendo,Yo le cambie ambos relays,la computadora y le puse una bomba nueva pero sigue asiendo lo mismo,Ahora si undo el relay manual con los dedos la bomba activa.Ahora la pregunta mia es a caso ese carro tendra aparte otro relay o fusible escondido en algun otro lado.Porque yo me eh metido en el manual del carro y asta en el internet y no aparece nada de un tercer relay o un cutoffswich,Si alguen deverda me podrian ayuda con este problemita que tengo se los agradesco un monton gracias,Y que pasen una feliz Navidad y a~o nuevos.Que dios me los bendiga a todos. :)
Apr 09, 2011 | 1995 Mitsubishi Mirage
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
El problema es que no le esta llegando corriente electrica a los inyectores del motor 1.6 vw 2003 polo hatchback y por lo mismo creo yo que no arranca
normalmente esta es una fusablie marcado --motor-- or --ign-- pero tambien alguino coches marcado en aleman ,yo sabe ingles pero aleman ?? tambien busca abaco el capo alado el battery por una caja de fusiblies grandes ,busca muy junto los cables e connections en esta caja ,si total bien --llamada grua por el concesionario falten una problems con el ordenador
Jun 20, 2010 | 1993 Volkswagen Fox
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Colores
El chassis de synch, no esta funcionando adecuadamente. Probablemente loose connections around.Si puedes quitar el tunner board y resoldarlo, hazlo; Pero la solucion esta en el chassis donde esta el tuner. Tambien lleva unos panel conectado verticalmenet, esos hacen mucho falsos. resoldalos. Por ahi si tienes dudas escribeme noetvs@embarqmail.com Hechale ganas!!!
Jul 29, 2008 | Sony KP-46S25 TV
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
