Question about Roundup Kitchen Appliances - Others
Round up toaster vct 2000 goes off by itself - Roundup Kitchen Appliances - Others
3 Suggested Answers
SOURCE: VCT-10 model toaster
I think if you replace the bushings (#2150150) that will keep the chains from getting stuck on the sprockets. I have to do this 1 or 2 times a year.
Posted on Feb 10, 2009
  • 6 Answers
SOURCE: where do I download a service manual?
put in roundup vct2000 torrents in googl u will get one there bud
Posted on Apr 29, 2010
Where is vct solenoid
Hi there:A code P0012 refers to the VVT (Variable Valve Timing) or VCT (Variable Camshaft Timing) components and the car's PCM (Powertrain Control Module, also called an ECM).
That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
A P0012 DTC trouble code may be caused by one or more of the following:
- Incorrect camshaft timing
- Wiring problems (harness/wiring) in intake timing control valve control solenoid system
- Continuous oil flow to VCT piston chamber
- Failed timing valve control solenoid (stuck open)
On Ford, the VCT solenoid is located at top of cylinder head underneath the valve cover and goes around one camshaft. You will need to remove the valve cover, the timing cover, then remove the timing belt, the camshaft sprockets, and finally the camshafts to remove the vct solenoid as it goes around the camshaft. You can use 2001-2003 models with same engine.
VCT or Variable Cam Timing solenoid is a device used in modern engines to change camshaft position timing in relevance to engine speed and engine timing allowing the engine to produce more horsepower without adding excessive overlap to the camshaft design.
The way the VCT Solenoid works is as follows:
The VCT solenoid works with oil pressure, it receives a signal from the ECM when the camshaft needs to be rotated either in the advanced mode or ******** mode depending on engine load and speed.The VCT solenoid is able to accomplish that by altering the oil flow in the passages that lead to the cam phaser(s), there are passages to advance the valve timing ( open the valves earlier), and passages that direct the oil to ****** the valve timing ( open them later)
The purpose of the VCT or Variable Cam Timing system is to allow the engine to move larger volumes of air in and out of the cylinders to generate maximum horsepower.
Vehicles with DOHC ( Dual Overhead Cam ) engines usually have two VCT solenoids mounted in each cylinder head, one for each camshaft, allowing the Engine Control Computer to activate each VCT timing mechanism in each Camshaft separately.
NOTE: The Cam phaser is mounted on the front of the camshaft(s) it is driven by the engine's timing chain or timing belt depending on the engine's design.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 20, 2012 | Cars & Trucks
The back belt doesn't spin but the front belt does.
The four sprockets that the chain is resting on have gone bad. Pull the side cover off so you get access to the belt wrap and the chain itself. In the corners those sprockets need replacing. You will see they are very smooth. The drive chain may have came off so it will not spin the one side, but i doubt that.
Jun 28, 2011 | Roundup VCT-25 Toaster
I am trying to reattaching the fencing...the grate, not sure what you call it. It's the piece that rotates.
First make sure you have not taken out too many links of the chain. Start on one side so you can get it together. Once that one side is on I take a channel lock and grab the other side that needs to get connected and get get it as close as possible the I use a flat head screwdriver and work on it until it connects. Takes a little practice.
Jun 08, 2011 | Roundup VCT-25 Toaster
Bread gets burn, to hot surface
Is the thermostat set correctly or is there an issue with the themostat? if the thermostat has gone bad try going to your local electrical shop and see if they can get a new thermostat
Feb 28, 2011 | Roundup VCT-25 Toaster
I have a round up bun toaster, and my specification demand that my toaster be a temp of 600%, I am getting a 400% max, my roaster will not allow me to increase the temp. I believe I'm follwing the correct...
for your size unit it is probably the max temp --check with the manufacturer if their is a thermostat up grade to boost temp or will you need a different unit
Aug 16, 2017 | Roundup VCT-50 Toaster
One of my GE toaster oven's 2 top elements burned out
Hello. It is very difficult finding parts for and appliance over ten years old. I recommend that you shop a bit for a new toaster oven. They are much less costly than they used to be and work better. Plus they have a warranty. J.
Jul 21, 2010 | GE Toaster Ovens
Where do I download a service manual?
Apr 12, 2010 | Roundup VCT-2000 Toaster
If i have on the display PH, Toaster don´t
The problem was in the switch under the upper shield, the switch was broken. So Thank You very much for Your support. Best Regards, Jan - Czech republic.
Jan 12, 2010 | Roundup VCT-2000 Toaster
P 1383 cougar 2000
P 1383 Variable Cam timing over-retarded (Bank 1) meaning the comprehensive component monitor (CCM) monitors the VCT position for over - retarded camshaft timing . The test fails when when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
Cause :
* Cam timing imprperly set * Continuous oil flow to the VCT piston chamber
* VCT solenoid valve stuck open.
* Camshaft advance mechanism binding (VCT UNIT)
Hope that helps
Jul 08, 2009 | 2000 Jaguar S-Type
Dec 25, 2007 | Roundup VCT-50 Toaster
Kitchen Appliances - Others Logo
27 people viewed this question
Top Roundup Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Roundup Kitchen Appliances - Other Expert? Answer questions, earn points and help others
