Question about Funrise Toys Toys
Instructions for great glass elevator game - Funrise Toys Toys
Ridgeway kelty 890110
http://www.kelty.com/t-instructions.aspx
This page should have instructions for Kelty products, but the search function has neither "ridgeway" nor "elevation" so perhaps it is actually a different brand?
Mar 20, 2014 | Kelty Elevation Ridgeway 4 Person...
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
Johnson 40hp- won't idle or troll at high elevations
Depending on the year model you may be able to adjust the mixture leaner for higher altitude. That adjustment was traditionally out of the very top of the carb pointing straight at you. Screw it in(gently- it's not a wood screw). Then out 1/2 turn at altitude.
Jul 14, 2012 | Light Boating
We need the game rules for the Great Dalmuti card game.
Try this link for Dalmuti. The file is an MS Word Document and includes hints in addition to instructions. I think this is what you're looking for. Please rate my reply - thanks!
Nov 09, 2011 | Video Game Consoles & Games
Drivers side window falls and wont stay up on track
It sounds like the window elevator is damaged, probably the fastener that holds the window glass to the elevator rail is broken, loose or just came off.
Take the door panel off and take a closer look. If the fastener came off the glass, JB Weld would fix it.
I hope this will help you, good luck
Mar 07, 2010 | 2004 Ford F150
My drivers side window does not work
the tracking that helps window go up and down is broken in door has to be replced its made out of a plastic tab that holds window
Feb 28, 2010 | 1994 Honda Accord
Eletric won't roll up or down. makes clicking noise.
The clicking tells me that the elevator motor is getting power. In my experience, these motors brushes wear out over time, this makes them weaker n slower to the point where they just stop working. You can get a replacement for about 40 bucks.
Before you go and get a replacement elevator motor, using utility gloves, remove old motor. Do this by holding the glass up using clear or duck tape if the window is rolled up, if the window is rolled down, insert a towel or a rag in one of the openings the bottom of the door then carefully remove the elevator motor and seat the glass on the towel, test it's funcionality while still plugged in. Also inspect the elevator hardware to make sure nothing is bent or broken, specially the fastener that holds the window glass to the elevator rail.
I hope this will help you fix your problem.
Good luck
Feb 27, 2010 | 1992 Mercury Grand Marquis
Fallout 3 freez
Try to save RIGHT before you think your gonna freeze then keep on trying to do that. Or maybe try to get the Pitt+Anchorage pack so you can get the patch.
Dec 15, 2008 | Microsoft Xbox 360 Console
False Elevation Edge 705
I have exact same problem. It has been working for 5-6 months but suddenly on one trip it now reads app. 280 meters too high elavation
Sep 03, 2008 | Garmin Edge 305 GPS Receiver
Toys Logo
32 people viewed this question
Top Funrise Toys Toys Experts
ray gallant
Are you a Funrise Toys Toy Expert? Answer questions, earn points and help others
