Question about Toys
Great glass elevator board game instructions - Toys
What is the elevation of this above sea level
Of what? You can find the elevation of any location using this great site. http://elevationmap.net/ Elevation maps with altitude finder for any location Altimeter tool
Sep 07, 2017 | Cars & Trucks
Ridgeway kelty 890110
http://www.kelty.com/t-instructions.aspx
This page should have instructions for Kelty products, but the search function has neither "ridgeway" nor "elevation" so perhaps it is actually a different brand?
Mar 20, 2014 | Kelty Elevation Ridgeway 4 Person...
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
My xbox 360 tony hawk shred board won't calibraite
we spent a day trying to calibrate the shred board, after much searching on the internet we found the solution that worked for us straight away was too - put two old and two new batteries in the board, we also elevated the board on a small stool this did the trick and now we can actually use it. Huray!!!
Dec 26, 2010 | Activision Tony Hawk: Shred
Elevation Will NOT go down after the elevation calibration
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3? If yes During Calibration, J5, between Pin 5 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board, do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
Jul 31, 2010 | RTO Bodyguard T200 Treadmill
Drivers side window falls and wont stay up on track
It sounds like the window elevator is damaged, probably the fastener that holds the window glass to the elevator rail is broken, loose or just came off.
Take the door panel off and take a closer look. If the fastener came off the glass, JB Weld would fix it.
I hope this will help you, good luck
Mar 07, 2010 | 2004 Ford F150
Eletric won't roll up or down. makes clicking noise.
The clicking tells me that the elevator motor is getting power. In my experience, these motors brushes wear out over time, this makes them weaker n slower to the point where they just stop working. You can get a replacement for about 40 bucks.
Before you go and get a replacement elevator motor, using utility gloves, remove old motor. Do this by holding the glass up using clear or duck tape if the window is rolled up, if the window is rolled down, insert a towel or a rag in one of the openings the bottom of the door then carefully remove the elevator motor and seat the glass on the towel, test it's funcionality while still plugged in. Also inspect the elevator hardware to make sure nothing is bent or broken, specially the fastener that holds the window glass to the elevator rail.
I hope this will help you fix your problem.
Good luck
Feb 27, 2010 | 1992 Mercury Grand Marquis
My 7222 copier will not start it is showing f-77-2
M7 (Elevator motor) drive abnormality
• While the elevate tray is going
up, the PWB-F (Elevate tray
top face sensor) is not turned
OFF in the specified period of
time after the M7 is turned
ON.
down, the M7 is locked.
• The S2 (Elevate tray upper
limit switch) or the S3 (Elevate
tray lower limit switch) is
turned ON in the specified
period of time after the elevate
tray starts to drive.
The main
body stops
immediately,
and the RL1
(Main) turn
OFF.
M7 (Elevator motor)
PWB-A (Control board)
PWB-F (Elevate tray top face
sensor)
S2 (Elevate tray upper limit switch)
S3 (Elevate tray lower limit switch)
FS-114 F77-2 M11-FN (Elevator motor) drive
failure
• During tray ascending, PC14-
FN (Top face detection sensor)
does not ON after specified
time from M11-FN ON.
• During tray descending, it
does not reach the target
position within specified time.
• During tray descending, M11-
FN is locked.
PWB-A FN (Control board)
PC15-FN (Top face detection
sensor)
UNPLUG FINISHER AND SHUT WORK
Feb 23, 2009 | Konica Minolta Office Equipment & Supplies
False Elevation Edge 705
I have exact same problem. It has been working for 5-6 months but suddenly on one trip it now reads app. 280 meters too high elavation
Sep 03, 2008 | Garmin Edge 305 GPS Receiver
Open Questions:
Toys Logo
71 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
