Question about Harmon Kardon AVR 700 A 5.1-channel audio/video receiver with 75W-per-channel output and Dolby and DTS sound
Left speaker is very quiet
The left speaker is very quiet in all surround modes, but works great in stereo mode. Is this a set up issue or a problem with the unit? This unit is also very finicky with hdmi communications, sometimes everything works together other times it's just sound or video. I have had problems since day one.
    New Friend:
  • 87 Answers
This may be a capacitor problem, evaluate and replace if bad.
Posted on Feb 12, 2014
2 Suggested Answers
SOURCE: Sound is really quiet with inputs
Hello. Please be sure that you are plugging your iPod into the tape in, or play, and not into the record out, or record. If you have these reversed, you will greatly lower the signal level going to the amplifier.
Dave
Posted on Oct 08, 2012
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Why do only 2 speakers play in steroe mode
stereo mode is just that - stereo. Stereo is two speakers, front left and right only. If you want the other speakers to play, select a surround mode.
Jan 29, 2013 | RCA RT2380 Home Theatre System System
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Two of the 5 speakers work on test but not for actual sound
you probably have to set it to multi chanal mode , while tv is most stereo the receiver has to decode that to 5ch
Apr 28, 2008 | Onkyo TX-SR504 Receiver
TX-DS494 Surround Sound Issue
don't switch to stereo mode. switch to prologic mode
Aug 06, 2007 | Onkyo TX-DS494 Receiver
Harmon Kardon AVR 700  A 5.1-channel audio/video receiver with 75W-per-channel output and Dolby and DTS sound Logo
Top Harmon Kardon Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
john h
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
