Question about Vizio Televison & Video
THE PICTURE IS WAY TOO LARGE. THE PEOPLE ON THE SCREEN FILL UP THE WHOLE SCREEN. IT USED TO LOOK NORMAL SIZE & ON CHOPPED WE USED TO BE ABLE TO WATCH ALL 4 CHEFS COOKING. NOW ALL WE SEE IS ONE CHE
PICTURE IS TOO BIG AND DO NOT KNOW HOW TO MAKE IT NORMAL SIZE WHEN WE FIRST GOT THE TV THE AD IN THE CORNER OF TV FOR NEXT SHOW WAS ONLY ABOUT A 2 INCH WIDE AND 2 INCH HIGH.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Posted on Feb 12, 2014
  • 280 Answers
SOURCE: picture is cut off
Try setting the set to 4.3 expanded on the aspect ratio. If that don't work try the other aspect ratio settings. That should make the picture fit the screen.
Posted on Jul 03, 2008
Coldcut
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
  • 3 Answers
SOURCE: high def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Posted on Apr 19, 2009
joeymille916
  • 143 Answers
SOURCE: LG TV MODEL 442L0520 SERIAL 005RMKUA3341 PICTURE
You need to go into the TV menu and change the settings for the display! Press the Menu button and adjust the Picture! It's probably set to automatic and not reading them correctly.
Posted on Sep 28, 2010
tampacannon
SOURCE: Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Posted on Apr 19, 2012
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Does anyone have an easy chicken soup recipe for me?
Chicken soup is one of the easiest things to make.
Take a whole cut up chicken, remove the skin and place it in a large pot. Fill the pot with water and two large pinches of salt and one of pepper. Add 3 chopped carrots, 2 chopped cerery and some parsley. Sometimes, if I want the soup to be a little thicker I'll add a cut up potato that will dissolve and thicken the broth. Cover it and let it simmer for 3 to 6 hours.
Feb 20, 2013 | Cooking
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Hi, my name is Nicole. My KV-36HS510 Sony TV is being broadcast with the picture size reduced quite a bit. Playing DVD's is fine, the pic fills the whole 36". However on cable TV it is chopped on the...
press "menu"
the setup screen should open
scroll through the options to "16:9 enhanced"
you should find 2 options ("on" and "auto")
choose "auto"
that should do it
enjoy.....
Sep 12, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sans e250 photo size
Do the fit screen option on the mp3 player. you are on the full screen mode, which for larger pictures cut them off.
Apr 14, 2008 | SanDisk Sansa e250 MP3 Player
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Picture size
They may have gotten to the zoom function. There is a zoom button on the cncealed part of my remote. Hit the zoom button to cycle through all the screen sizes.
Oct 26, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Televison & Video Logo
180 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
