Question about Xerox DocuPrint C3055DX Laser Printer
ERROR CODE 116-324
HOW DO I FIX ERROR CODE 116-324 REBOOT PRINTER
How do I fix error code 004-332
That error code signifies a developer home position sensor error. Can you move the carousel by hand? It also may be that a toner is leaking and has spilled onto the home position sensor.
Oct 04, 2014 | Xerox DocuPrint C525A Laser Printer
Error P07 and 5b02 ON CANON MG3150
The error number means a certain problem. You will have to reboot the machine. If the error code is still there, you will have to fix the problem before the code will go away.
May 19, 2014 | Canon Office Equipment & Supplies
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Oct 03, 2011 | Samsung CLP 315 Laser Printer
I am geting printer error message 54.18
Hi,At printer start, receive the following message: PRINTER ERROR 54.18. According to the HP error code message reference, this is a black cartridge sensor malfunction. Cleaned the sensor contacts, replaced the cartridge and rebooted; same error. Is there another fix for this?
Thanks for using fixya.....
Oct 25, 2010 | HP LaserJet 5550 Printer
How to reboot printer Xerox DocuPrint C4350 error code : 124-315
How to reboot printer Xerox DocuPrint C4350 error code : 009-383
Oct 24, 2010 | Xerox DocuPrint C4350 Laser Printer
ERROR CODE 259
Sounds like a print spooler error.
The easy fix is remove and re-install the printer and reboot the PC
Apr 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
Apr 12, 2008 | HP LaserJet 3030 All-In-One Printer
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Xerox DocuPrint C3055DX Laser Printer Logo
173 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
