Question about SanDisk Sansa e200 MP3 Player
E200 wont turn on
E 200 wont turn on i hit the on button and it jus keep restarting itslef
wat should i do
  • Anonymous Dec 20, 2007
    When i turn my sansa e200 on. The screen goes black
  • robertovar Sep 28, 2008
    power buttom will turn on , but screen will stay black .
Byt how cud we install another firmware if da screen black and we cant get it to go in recovery mode
Posted on Nov 22, 2008
Re-Install Firmware... dats what i did and it works nice...
Posted on Dec 19, 2007
The mp3 keeps restarting if you turn it on
Try and connect it to another computer the back 2.0 or laptop and format if recognized
Jun 28, 2010 | SanDisk Sansa e200 MP3 Player
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
My sansa e250 gets frozen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Wont come on
Make sure the hold switch is not engaged.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa e250 MP3 Player
Won't turn fully on
1. Download recover.rar from here
2. unpack the libusb-win32-device-bin-20060827.tar.gz to (example) c:libusb
3 find e200tool.zip and unpack it to (example) c:e200tool
lots of archives isnt it )))
DRIVER:
1. connect using manufacturing mode (hold button on + center button while connecting)
2. In device manager find unknown device under USB and update the driver. Select driver manually. Navigate to 0781-0720.inf (came with the archive) (c:e200tool)
3. When windows promt you to install "libusb0.sys" direct it to с:libusblibusb-win32-device-bin-20060827in
4. Start-> run -> cmd
5 type:
cd
cd e200tool
e200tool recover BL_SD_boardSupportSD.rom
6. windows will find another usb device so instead of "0781-0720.inf" choose 0666-E200.inf
7 disconnect player and restart it
STEP 3 (recover bootloader)
1. connect player in manufacruring mode
2. Start-> run -> cmd
3 type:
cd
cd e200tool
but before you hit enter press and hold record button (very important)
Step $ (firmware update)
1. connect player in recovery mode
2. copy PP5022.mi4 to 16 mb partition
3 restart player
OK and now If you screw it up - it is not my fault ))
Nov 20, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Jun 27, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 won't unlock
slide the hold button @ the top of your player the other direction. hen turn on. this should solve it.
Feb 12, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 froze
hold the menu button for about 15 sec. and it'll turn off
Dec 28, 2007 | SanDisk Sansa e200 MP3 Player
E200 Voice Recorder gone mad!
Maybe the recorder button is getting stuck? You can disassemble the unit and see if anything is in the way.
Sep 06, 2005 | Casio Cassiopeia E-200 Pocket PC
SanDisk Sansa e200 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
