Question about Zenith Z50P3 50 in. Plasma TV
I have audio but no picture on my Zenith Z50PG10 50" plasma tv?
There is a buzzing noise coming from the tv. The audio works but not the picture.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Plasmas are like tube TV's(CRT). Once the plasma tube breaks, air gets in, plasma gas gets out. And that's it. They are an enclosed vacuum picture tube. I don't know why people buy plasma. The newer LED have a much better picture. Rich people who swear by plasma, are ridiculous in my opinion. Again, if plasma tube breaks, thats it. Any wrong jarring can break a plasma tube.
Posted on Feb 12, 2014
SOURCE:
  • 3 Answers
SOURCE: Zenith Plasma TV Manual
I found it posted here MFL34797058_0.pdf
This is the web site...
http://tv.manualsonline.com/ex/thread/view/idThread/329713
Posted on Jun 03, 2009
  • 8 Answers
SOURCE: 50 inch plasma zenith tv power and picture comes
Stretchlimo. Thank you for such a good response to this person's question. I am also having the same problem. However, I found that if you push in on the power button and hold it in, until the Green "Power on" Light stops blinking... the video will resume. I do want to go ahead and get said part, that you were speaking of. Is it a Power Converter/Transformer, or something along those lines? Can you point us in the right direction; as to where to get said part? Thanks again.
Posted on Dec 24, 2009
SOURCE: zenith 42" plasma p42w46x
I have the three zenith plasmas, I've fixed the two that were flickering. The one with the verticle lines, I sawpped the Z-SUS and the Y-SUS from the good TV to the bad and still had the white lines. I looked at the two boards hooked together with 3 aluminum covered ribbon cables that are in the lower center of the TV with all the video inputs, on the far left there is a right angle connector that has about 20 pins, the white cable comes out and goes under to a circuit board this looks like this cable supplies the video signal to the screen. I disconnected the cable and the screen went black, all the voltages going into the video board are normal, so there must be something fried on one of the two boards, there are a LOT of electrolytic caps on those boards. I will post when I figure out whats cooked, you may have the same problem too.
Posted on Dec 26, 2007
SOURCE: zenith plasma tv
my 52 inch zenith plasma has no picture,but has a perfect sound.what could be the problem?
Posted on Dec 03, 2008
SOURCE: No picture on plasma
Thank you for responding about my problem but from your other members find my solution.
Posted on Mar 31, 2009
Zenith plasma tv wont stay on model:z50pj240
This could be caused by multiple things. The first problem that comes to mind is a bad power supply in my experience. The second problem that comes to mind is possibly a bad t-con or backlight inverter board. Could you tell me, when the TV powers back off can you see a picture in on the screen if you shine a flashlight up to the display?
Dec 23, 2016 | Zenith Televison & Video
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Mar 23, 2011 | Zenith Z50P3 50 in. Plasma TV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
Zenith P42W22H: Accidently turned on stereo while TV was on. Speaker system provides sound for both Units. Stereo popped with power error. TV Popped and went off. I shut down power to both. The Stereo...
Go to this Website Encompass Parts Distrubtion and type in your Model# Look for Audio output IC
1-800-638-3328 and try Zenith Exchange Moduels
1-800-632-6637
Jan 14, 2010 | Televison & Video
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
Plasma tv
Hi!
what do you mean sir you have no picture but you have sounds?
Nov 01, 2007 | Televison & Video
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith Z50P3 50 in. Plasma TV Logo
331 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
