Question about Car Audio & Video
I have kenwood rxd-f2 . it was on and it got extra voltage. now its not working. the current condition is now when I turn it on, the display turned on for 2/3 seconds and then it shuts down. few green
I have kenwood rxd-f2 . it was on and it got extra voltage. now its not working. the current condition is now when I turn it on, the display turned on for 2/3 seconds and then it shuts down. few green -------------- dots blinks starts, some times "auto power control on " also displays.
SOURCE: Can't get to turn the sub On-Off
I had the same problem. The people at Kenwood are idiots when it comes to writing instructions. What you have to do is go to standby mode, hold the menu button until the menu displays. Now, scroll down to where it says "Rear." Push the control knob to the right. Now you have the ability to turn your sub on and off. Once that's done, just go back to CD or Tuner, push the knob down, hold for the two seconds, then it should say "On Sub." It took me a while to figure this one out.
Posted on Oct 17, 2007
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
  • 4 Answers
SOURCE: Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Posted on Aug 06, 2008
  • 3 Answers
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Posted on Sep 22, 2008
JustJeeps
  • 74 Answers
SOURCE: JVC KD-S70R
you have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Posted on Nov 28, 2008
Kenwood Hi-fi component RXD-M1MD is not working
I have kenwood rxd m1md . it was on and it got extra voltage. now its not working.
Please tell me what happend to this unit? which IC or part have to change?
Thank You
Jun 13, 2012 | Audio Players & Recorders
Kenwood RXD-G2 clock setting
My kenwood is not a car system but it is
KENWOOD entertainment system
RXD-G2
Turn power on at wall
Clock is flashing
Press clock
Press memory
Hour flashes
Press up/down to set Hour
Press memory
minute flashes
Press up/down to set minute
Press memory
Press power on buton
Feb 13, 2012 | Car Audio & Video
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Oct 23, 2011 | Kenwood KR-V990D Receiver
KENWOOD RXD-V555 PROTECT MODE WAS APPEARED . i CANNOT OPEN MY COMPONENT
MY MODEL IS RXD-V555 , LAST 1 YEAR NOT USE AND NOW START BUT PROBLEM IS WHEN POWER IS ON GO ON PROTACT MODE AND NO SCREN. PLEASE HELP
Oct 15, 2011 | Car Audio & Video
There's a problem with my Kenwood vr-506 the power
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 22, 2011 | Kenwood Audio Players & Recorders
Hi.well I have a problem with my Kenwood and I've
Kenwood RXD-A75 CD Drawer Stuck shut and ERROR message appears on display.
Look for a miniature little hole somewhere on the face of your unit,. Get a paperclip (smallish) straighten out one end and insert into holr. It might say reset, might not. You want to do a sort of heimlich manuever thrust (miniature style), insert the paperclip, thrust about a quarter of an inch, and the drawer should pop open. At least enough where you can "help it gently", don't yank its slide mechanism out, but verbally threatening sometimes helps............ Sometimes...............
Oct 02, 2010 | Kenwood XD-A75 CD Shelf System
Kenwood rxd-355
It's a safety measure by design to avoiding overloading your stereo system.
May 31, 2010 | Kenwood Audio Players & Recorders
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Kenwood RXD 501
Do you already check the thermal fuse on the primary side of the transformer
Oct 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
