Dodge 5.9 gas engine wont idle when cold
Wont ide,hard start,bad fuelmilage
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Might be bad ignision candels.
Posted on Feb 18, 2014
Have a dodge ram 50 pickup.. Hard to start.. Once started it will idle... Try to pull out and it hesitates and wants to die.. Back off on the gas and sometimes it will idle or dies..
Dodge Ram 50 Pickup Questions - Page 5 - CarGurus
www.cargurus.com > Questions > Dodge
CarGurusGet fast answers to your Dodge Ram 50 Pickup questions from experts in the ... 1986 Dodge Pick Up 5.9 Wont Start I Put New Distributor Set The Timing, New.
Dodge Ram 50 Pickup Questions - Carburetor - CarGurus
www.cargurus.com > Questions > Dodge > Ram 50 Pickup
CarGurusCarburetor - I recently bought a 1989 2.6L Ram50 for my son. ... Asked by redoverfarm Apr 13, 2010 at 03:36 PM about the 1989 Dodge Ram 50 Pickup ... check your fuel injector...may be clogged dirty, get a fuel injector cleaner or carburator ... Also gets poor gas mileage and is hard to start when the engine is warm !
Dodge Ram 50 Pickup Questions - 87 d 50 2.0 runs ok ...
89 Ram50 wont start.. - DodgeTalk : Dodge Car Forums, Dodge Truck ...
www.dodgetalk.com > ... > Dodge Ram Truck 1st Gen (88 - 93) Forum
Sep 22, 2011 - Hey guys i got a 1989 Ram 50 and im hoping i can get some help here. She drives like a champ but she only starts when i push start it, once i ...
Dec 26, 2015 | Dodge Cars & Trucks
Just bought. 5.9 cummins Can`t get it to start without pushing gas pedal slightly. Runs good after warms up. Still have to give it fuel to start.
Numerous Conditions May Cause Engine to Crank But Not ...
repairpal.com > Problems > Dodge > Ram 2500
2006 Dodge Ram Laramie 2500, 5.9i liter Cummins ... I know in the old days the dodges had a way about starting up an engine and that would be where.
White smoke, rough idle at startup - Dodge Cummins Diesel Forum
www.cumminsforum.com > ... > 3rd Gen. Powertrain
Jun 5, 2010 - 9 posts - ‎7 authors I have an 06 Dodge 5.9L that has a light white smoke and rough idle when first ... 2006Ram 2500 QCSB 4x4, 3" Carli coils w/ 1" Daystar spacer, ... Still ran good tho, dispite the exact conditions you describe on Cold Start up.
Oct 20, 2015 | 1995 Dodge Ram 3500
1995 Buick LeSabre 3.8 Liter Wont start unless I push down on gas pedal like it wants more gas, Why? Runs OK when running
Possibly a bad or dirty Idle Air Control motor. The engine computer controls the operation of this motor to control idle speed. A pintle on the motor extends and retracts, according to signal from the computer. The pintle controls an air passage below it to give or take away air during idle -when the throttle shaft is closed, no air will get into the engine through the throttle body except through the idle air passage . The IAC motor or valve is on the throttle body, with a 4 wire connector. Take it off and look for carbon or coking deposits around the valve's pintle, and in the air passage beneath it. With the idle valve off, plug the connector back on it, then watch the pintle as the key is turned to on. If there is no movement whatsoever, the motor is probably bad.
I have also heard that a bad coolant temperature sensor can cause such a hard start. If the computer does not know the engine is cold, it won't put enough gas into the cylinders for easy starts. The engine needs more gas to start and run when cold.
Sep 13, 2014 | 1995 Buick LeSabre
2000 Caravan won't start cold unless I rev engine for 5 min
You need to check the cold choke set up, which may be called a IAC
Idle Automatic Control this is sensor works the am starts for cold or hot idles...
Do you have a light on??
Oct 23, 2013 | Dodge Caravan Cars & Trucks
Will not idle when cold
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Dec 14, 2012 | 1999 Jeep Wrangler
Won't start easily since it got cold (32degrees). It's fine once it starts
These will help.
Thanks.
Dec 14, 2012 | 2004 Dodge Ram 3500 Truck
98 dodge ram 5.2l 4x4. Trans/Idle problems.
It won't shift 1-2 or 2-3 or both unless you let off? If it is just 1-2 it might be a band adjustment, but I'll bet you have a plugged governor solenoid screen also.
May 17, 2010 | 1998 Dodge Ram 1500 4WD
89 dodge shadow. hard start. normal idle cold, fast idle warm. sometimes it wont start until i hear fuel pump activate.
The car may be hard to start because it may need a normal tune-up. If the spark plugs are pretty used, they will slowly stop burning as much fuel because the spark slowly gets lesser and lesser. On a cold day the fuel is harder to ignite with a small amount of spark.
Normal idle when its cold means that your cars idle is probably too high. If you lower the idle, the choke on a cold day will keep the idle a little higher until the motor warms and then it will kick back off. If the idle is too high, it will run very rich, smothering itself with fuel, and causing the idle to stay low. When the car warms, its creating better spark when its warm, and with the idle being too high its running at a fast idle.
The car wont start sometimes can be the cause of a few things. If the ground is bad on the fuel pump, it wont make a good connection sometimes for when you turn the key on, the fuel pump dont pump the fuel to the engine. Another one can be that your accessory switch can be loose going to the fuel pump. I think its your ground though. Good luck! Hope this helps.
Have a nice day. -Steve
Dec 06, 2009 | 1989 Dodge Shadow
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
