Question about Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414
Food in refrigerator keeps freezing - Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414
  • 4 Answers
Check if your thermostat is not set on high and lower it. Listen to the sound of your fridge and should ocassionally go to defrost mode which should happen automatically and should be silent for not more than one hour.
Posted on Feb 12, 2014
My freezer is too cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 04, 2011 | Kenmore Freezers
My freezer is too cold - things are rock solid
heatman101
Jan 04, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
This is an upright Kenmore freezer. It keeps cold for a few months and then loses its coldness. Turning up the thermostat has no effect. This has become very frustrating since we have to throw out the...
I suspect, you have low refrigerant in freezer. You may have a leaking pipes. Please get fix the leaks first the top up your refrigerant to normal level.
Sep 02, 2010 | Freezers
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
Halfway frozen
If the condenser coil is clean and its fan works ,probably the unit is low on refrigerant which means there's a leak that has to be repair before recharging the system.
Sep 13, 2009 | Kenmore Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414 Logo
47 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
