Question about Husqvarna Garden
Sl-yd5200b new start problem
New difficult to start. Stiff.
    Sergeant:
  • 458 Answers
If it is new it may still be under warrenty. I would take it back and have it repaired under warrenty.
Posted on Apr 11, 2014
I have a SL-YD5200b model chainsaw and am looking for a chain lubrication pump and the bits and pieces that go with it, Hoping you can point me in the right direction,Thank You J Spedding vivjimuk@yah
Afraid not much here it is a Chinese chainsaw. You need to contact
Trueshopping co uk for parts which very well be hard to come by if anything like what we deal here in the USA on these kinds of equipment.
We have a company called Harbor Freight that sells equipment and when it breaks down can even get the spares that we need. So we have similar problems which why I tell my customers not to buy anything at HF unless they willing to just it away when it breaks.
Good Luck
Oct 30, 2014 | Garden
1998 Saturn SL just won't start anymore.
assuming it will turn over ('cranks"), my bet would be the crank sensor has failed, and it is not to difficult to change if you can get the car in the air high enough to get fully under it. The sensor is located just above the starter, on the side of the engine closest to the firewall. It is held in place by one bolt, and you will need to remove the electrical connector to remove it. a new one is usually less than $50, and almost any auto repair shop should be able to replace it for less than $125.
Apr 08, 2014 | 1998 Saturn SL
Sl-yd5200b
If the saw is fitted with a decompression switch you need to decompress the cylinder after every pull to make it easier to start. If it doesn't have a decompression switch you need to put the saw on the ground and put your right foot firmly into the handle opening, place your left hand on the top hand bar, grip the pull handle and pull out slowly until you feel a solid wall or compression and then pull straight up fast and hard for about 8 - 10". Make sure the brake is on when starting. I have an older Husky saw and this is how I start it. It has a short pull cycle so don't try to give it a long pull like a weed whipper!
Feb 12, 2014 | Husqvarna Garden
Honda crf 100
You possibly have corrosion or contamination built up in the lever pivot point. Disconnect the cable and try lever - if it is stiff or difficult to move, you'll need to take the handle off, clean pivot and contact points with a SOFT wire brush ( brass brush recommended) lube it with white lithium grease and re-install. check for freedom of movement before re-installing cable. If it moves ok but cable is stiff, you'll want to next lube the cable with a liquid spray lube - sometimes the new cables are not properly lubed!!
Apr 27, 2013 | Motorcycles
Stiff turning the wheel, we have power steering. have had a flush done and a new pump put on also, but still hard to turn. any ideas?
i would think about some grease in the ball joints and tie rod ends, and about the upper strut bearing. at 10 years any and all of them could be worn, causing drag on the steering.
Sep 06, 2011 | 2001 Saturn SL
I am using a new shimano 6603 SL braze on derailluer with a fairly new, but in good shape shimano 6603-G crankset, but an older 6510 triple shifter, all with a 9 speed chain. Shifting onto the middle and...
It is hard to tell via the Internet. I suggest that you take it to a bike shop. They will get it shifting smooth, and, if not tell you what is wrong.
Jul 22, 2011 | Shimano Ultegra ST-6603
Need to tighten rear view mirror of 1997 Mercedes SL 500. It does not firmly stay positioned, it moves too freely. Failed safety inspection. New one cost $900 from dealer, can find used parts
OK what I put here is for the E class Mercedes of the same era. Generally Mercedes shares build concepts and ideas across different classes of car. The mirror assembly consists of a mirror frame socket fitted to ball on the end of a mount arm. If the mount on the SL is the same then the idea is to stop the mirror from moving freely on the ball. It should be possible to slip the end of a clothing pin(s) between the ball, which is steel, and the socket, which is plastic. Force it gently in and check for the degree of play in the mirror. Once the mirror is stiff clip the protruding remaining length of pin(s) away to keep things looking tidy. Crude, effective but, above all, much cheaper than $900
Jun 23, 2010 | 1992 Mercedes-Benz SL-Class
Stiff focus wheel
The number one rule is to never use oil on a binocular!!
I suspect that the multistart thread on the focus arm carrier, which is internal, has become gunged up. This is not an easy repair for a beginner. The rubber has to be removed from the body of the binocular before you can even start to take them apart to determine the fault.
Like any bearing or gear system, the part would have to be cleaned with a degreaser, then reassembled with new lubricant.
Jan 04, 2010 | Pentax PCF WP II (8x40) Binocular
Garden Logo
49 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
