Question about Sanyo 42 in. LCD TV
Sharp aquos 42 yellow spot in middle of the screen
I have a yellow tint in the middle of the screen.
I have a light yellow color in the middle of the screen.
It has something to do with the display. In order to ensure, it is not caused by the input device, connect a DVD player and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I ger AMP error ("Pull out AC cable, check your connection) all the time in all inputs of a new 46" Sharp AQUOS LC-46D85U 1080p 120Hz
I had the same problem with a Sharp Aquos 40". Sound just for a second and the message all the time in the middle of the screen, no more sound.
I opened the TV and found a speaker cable (a black one) with the PVC isolation broken and the wire in contact with the chassis. I just isolated it, the sound came back and no more error message.
Sep 01, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have a yellow tint in the middle of the screen
i have a yellow cricle on the middle of my screen how do i fix it
Jun 07, 2010 | Sharp Notevision PG-B10S Multimedia...
Dark lines on Sharp Aquos 42" screen.
if the unit is stll under warrenty it would be best to take it back, it does sound like that it is the lcd that is faulty, or contact Sharp to see if the can repair it for you
Thanks
Oct 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Dark line down the middle of the screen
There are two sets of wires internal to the LCD. one of the wires has come loose. Complete dissassembly and reassembly should solve the problem. (use electrical contact cleaner on the gold tabs that insert to the LCD)
(take it back if under warranty, and haggle to get it replaced even if it isn't first. Following the above procedure is an easy way to break the light tubes if you're not super careful.)...
Apr 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
Mar 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo  42 in. LCD TV Logo
22 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
