Question about Irons
Laura star boiler does not heat - Irons
My rowenta dg5030 will heat but the water will not heat
The Boiler unit is not working have it repaired, or get a new one!
Jul 26, 2014 | Rowenta DG5030 Iron
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
Apr 24, 2014 | DeLonghi Stiromeglio Compact PRO 300 Iron
Power steam elite boiler screw is stuck
Morphy Richards Power Steam Elite boiler screw
Mar 16, 2013 | Morphy Richards Irons
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
The boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 25, 2009 | DeLonghi Stiromeglio Compact PRO 300 Iron
Steam button on iron has stopped working yet iron still heats up and light on boiler still goes on.
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
Jun 10, 2009 | Rowenta Steam Generator DG050 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
26 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
