No power to display monitor
No display to front of machine not running.
Chek on fuse in box machine's
Posted on Feb 12, 2014
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Machine wont boot
There is your answer no power to the monitor. Make sure it is plugged in replace with another monitor if you cannot get the button on the monitor to power on the unit. Maybe time for another monitor. John
Apr 20, 2012 | Dell XPS 210 PC Desktop
Nothing on the monitor, the computer powers up and e machine f2 comes up on the screen then goes blank
hello bradprice258
I am assuming you have an LCD monitor
when the computer turns on look carefully at the front face of you computer case, there are two small LED lights. one is power and one is hard disk activity.
look at the one for hard disk activity. watch it for a few mintues, if it is activly blinking and then turns off or becomes a random blink then it means the possibility is a faulty monitor. LCD monitors do that once they age or get hit by power surges or black outs.
if both lights in front of the case go out as you loose display then the problem is with Po itself. could be bad power supply of main board.
hope this has been of help.
please do leave comment if this has helped.
Feb 10, 2011 | E-Machines eMachines Desktop PC
My cpu has power but i cant see anything on my monitor
Check that the Monitor power cable is firmly connected to the mains and the back of the monitor. Do u have the Power light on in front of the monitor?
Check the Signal cable running from the Computer to the Monitor. Is it firmly fixed at both ends?
If still no joy, plug a known working monitor to your computer. If u get a display, then your monitor might have gone bad or it might have been set to the lowest brightness (check the setting knob).
If swap monitor does not also work, then your Display (VGA) card is suspect, faulty. You may want to replace your VGA card.
May 02, 2010 | HP Pavilion a705w PC Desktop
No monitor display when machine is turned on.
Well first two questions and my apology if this sounds elementary but I need to ask. First, is the monitor plugged in to the back of the computer (the tower)? Second, is the power plugged in to the monitor? Just because you have power to the tower does not mean the monitor has power. So at a minimum you must have two cords running to the monitor for it to function properly.
Dec 23, 2009 | Dell Dimension 2400 PC Desktop
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Possible_backlight_issue
Hi goldeneye, Sounds like the backlight inverter board. Don't mind the explaination I just cut and paste this solution from one of my others. It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 23, 2006 | Kogi L7CH Monitor
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
