Question about Intel Computers & Internet
Bios battery removal - Intel Computers & Internet
    Habit-Forming:
  • 106 Answers
The bios/cmos battery (usually a button type) is fairly easy to remove and can be done anytime the computer is unplugged from the power (switched off at the wall) however it is recommended that this procedure only be done by trained personnel
NOTE: removing this battery will reset the system date and time
Posted on Jan 26, 2016
How to bypass bios password for samsung NP-N102S
There is no magic software that will reset the BIOS password if you forget it. The only way to clear this problem is to remove the BIOS battery. Also, unplug the power cord adapter and remove the main battery before you remove the BIOS battery. If your in a hurry, after removing the small round BIOS battery short out the two pins the battery was plugged into to totally drain the capacitors on the motherboard. No harm to the motherboard, your just discharging any left over charge on the capacitors. The BIOS battery is usually under the keyboard and this will have to be removed to get at the battery.
Regards,
Dennis
Mar 27, 2014 | Acer Aspire Computers & Internet
Emachine d620 bios password
This works for me when I'm faced with this but its tricky unplug from wall remove battery, remove Hard drive locate bios battery this requires opening the laptop disconnect De-solder whatever it takes to remove the battery press and hold power button for 30 seconds with the bios battery removed reassemble with fresh bios battery or reuse old one "yuck" boot without hard drive into bios it should be at factory defaults hope this helps :)
Nov 08, 2013 | Computers & Internet
I have IBM ThinkPad computer A22m 2628 and i have fogotten the BIOS password...how do i get it fixed
Remove the main battery and unplug the CMOS battery if you can get to it or you can try to hold the on/off button for about 30 seconds. This should reset the BIOS to factory defaults and you can then get back in and reset a new password.
Sep 25, 2011 | IBM ThinkPad A22m 2628 Notebook
I forgot the bios Password can you help me please
Depending upon your model laptop, you may be able to remove the BIOS password by removing the BIOS battery for 20 mins so the CMOS can completelt discharge, then insert the battery and go to the BIOS configuration and set the Date & Time etc.
If this does not work the the BIOS password is stored on an EEPROM chip and removing the BIOS battery cannot remove this password. There are no backdoor passwords available.
Jun 24, 2011 | Computers & Internet
How reset the bios password
There are a couple of solutions available to you. One is to switch the bios jumper on the motherboard, the other is to remove the bios battery (looks like a watch battery) for 5 minutes. *Note removing Bios battery will reset all bios settings not just password. Have a good day
Jun 21, 2011 | Toshiba Satellite A45-S121 Notebook
HOW TO REMOVE PASSWORD FROM BIOS
Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
Feb 04, 2011 | MPC Computers TransPort X1000 Notebook
Oh my laptop IBM R60 bios password and try by removing cmos battery but still please email me if u got the ideal
Removing the BIOS battery did not reset the BIOS password because the BIOS password is stored on an EEPROM chip. visit laptopmasterpassword.net
Sep 24, 2010 | IBM ThinkPad R60 Notebook
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
Bios battery location
On the R40, you will need to remove two things to get to the BIOS battery: 1) the regular battery, 2) the Keyboard. The BIOS battery is located just underneath the keyboard. In order to remove the keyboard you have to remove two screws from the bottom of the notebook (each will have a little picture of a keyboard and arrow next to it). Pop the keyboard up gently and the BIOS battery is just above the mouse buttons.
Check out the service manual for more details (pages 68, 77, 85).
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-45899
Apr 28, 2009 | IBM ThinkPad R40 2681
I have ibm thikpad model 2647.i forget bios passward
Make sure that in addition to removing the bios battery, you also remove the main battery. Then turn it on while the bios battery is out.
Mar 23, 2009 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
