Question about Magic Chef Refrigerators
How to fix lower door hinge pin
Lower door hinge pin broken
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
22yooper
  • 828 Answers
SOURCE: self closing door hinges
This is not a refrigerator problem BUT, you must insert a tool like a drift punch into one of the holes on the top of the hinge and rotate it away from the door position then reposition the holding pin to prevent it from recoiling.
Posted on Jun 28, 2008
SOURCE: broken hinge
You can purchase a new hinge. We have access to all Ascend/Coldtech parts. Please forward your model and serial # to sales@cullincini.com. We would be happy to help out. Dante Cullincini
Posted on Aug 17, 2009
SOURCE: dometic rm2804 door hinges are worn and plastic
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Posted on Nov 28, 2010
SOURCE: Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Posted on Aug 06, 2011
Hi. I have rust on my sr-s27fta Samsung refrigerator and I'm trying to take down the door in order to fix it. Do you know how can I do that?? Thank you
There's a plastic cover on the top door hinge. Pop it off and remove the screws that fasten it to the top of the fridge. Pull it off and don't loose the washers on the hinge pin. Lift the door up off the lower hinge pin. If it's the freezer door, do the same but take off the lower toe guard grille to expose the water tube going to the water dispenser. Separate the hose at the in line connector at the bottom of the door before you lift the door up and off the hinge pin.
Mar 25, 2016 | Samsung Refrigerators
My 1993 Ford F250 driver side door will not shut unless I lift up on the door from the outside. Is it the door hinges that need replacing or what?
You may have to replace the hinges but most aftermarket suppliers have pin and bushing kits to repair your existing hinges. A phone call to your auto parts supplier can probably fix you up for a fraction of the price of new hinges.
When you go about fixing the door, an old bumper jack is the best tool to use, if you have one. It will support the end of the door while you remove hinges and make adjustments.Otherwise you will need a helper. BE SURE to mark the position of the hinges before you remove them so you can put them back on easily. If you don't mark them it can take a looooong time to get them adjusted properly. Hope this helps.
Aug 29, 2011 | 1993 Ford F250
How to put in a upper door hinge pin
Put a jack under the door with a piece of 2x4, as close to the middle as you can. Jack up the door, watching the hinge pin until pin is in the center of the movement range. Put a long metal rod or socket extension on the bottom of the pin and tap out with a hammer. Use same rod to remove bronze - alloy bushing. Tap new bushing in and use a 16 penny nail to check alignment of holes in hinge to bushing, raise or lower jack to center. Tap in new hinge pin. Release jack and check door for alignment on latchpin - If low, jack up door to relieve pressure, loosen upper / lower hinge bolts, raise door with jack approximately 1/8 inch, retighten bolts, remove jack and test Repeat procedure until pin strikes the center of the latch..
Nov 10, 2010 | 1991 Ford Explorer
The doors on my 1989 Ford Mustang (hinges) sanging. What is the fix for this? (maybe hinge pins or total hing replacement). Also, door handles outside stick and dont operate correctly? Idea fix?
You may need new hinge pins, replacement of the catch pin may be helpful as well. The plastic bushing on these tend to go bad letting the door hang lower and making it difficult for the handle to open the door.
JTRadiojunkie
Aug 12, 2010 | 1989 Ford Mustang
Door is not level, how do I fix?
There should be some adjustment in the door hinges. Check the hinges to make sure the pin that enters the door is not broken. If it is, dril out the pin and replace it with a small bolt, put two nuts on the bolt and use the top nut to adjust the hight of the door.
Aug 11, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
Jun 25, 2009 | Dometic Refrigerators
Refrigerators Logo
13 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
