SOURCE: replacing a rear axle on a 94 jeep grand cherokee 2wd
take the rear cover off of the rear end. make sure you have something to let the fluid drain in. turn the carrier until you see a 5/16ths bolt. take the bolt out and let the pin in the center of the carrier slide down enough to be able to slide the axle inward. that will release the c-clip. then when the c-clip i removed you can just pull the axle out of the houseing but mak sure to not let the carrier spin any while you are pulling the axle out.
SOURCE: release excellorator makes clicking noise turn
Sounds like your thinking in the right area. Up on stands or hoist look for ripped boot, and/or movement at joint.
SOURCE: Noise coming from my passenger side wheel well
yes, it could be, and probably is, to check this, jack the car up, and see if you can wiggle the tire, up and down, or side to side. also, you might want to check your brake pads. hope this helps!!!
SOURCE: I think I need to
Regards,
Tony
SOURCE: pontiac grand prix passenger side cv axle
ello, ello. You just push hard till you hear the little circlip on the end of your axle shaft "click", meaning it has seated inside the transmission.
