Question about Philips LFH0884/27 - Digital Voice Tracer 884 Digital Recorder, 8GB
Philips voice tracer lfh0884 power on and shuts off
When the power button is pressed the display lighhts up for a few seconds and goes blank
4 Suggested Answers
  • 34 Answers
SOURCE: philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Posted on Nov 03, 2008
paulbtorrent
  • 34 Answers
SOURCE: Philips 190S monitor - Urgent!
The lcd has three parts the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flatheaded, practice using two pennies stuck together()with your finger after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
josema_sv
  • 500 Answers
SOURCE: Can someone please explain in English why the
The first requirement is that you must have video coming from your PC, then you have to press and hold for more than 10 seconds the "MENU (OK)" botton, this must unlock the OSD controls of your monitor.
Posted on Feb 10, 2011
User manual philips voice tracer DVT4100
[PDF]User manual - Philips
https://www.dictation.philips.com/index.php?...
Philips1 Important safety information. 5. 1.1 Safety instructions. 5. 2 About this user manual. 7. 2.1 Symbols used. 7. 3 Digital Voice Tracer. 8. 3.1 Product highlights. 8.
Voice Tracer digital recorder, DVT1700 - Overview - Philips
https://www.dictation.philips.com/.../voice_tracer_digital_recorder...
PhilipsVoice Tracer digital recorder. Speech to text. DVT1700 ... Manuals and documentation. Quick start guide (1.3 MB); User manual (867 KB); Leaflet (563 KB).
Philips1 Important safety information. 5. 1.1 Safety instructions. 5. 2 About this user manual. 7. 2.2 Symbols used. 7. 3 Digital Voice Tracer. 8. 3.1 Product highlights. 8.
Apr 24, 2015 | Philips Audio Players & Recorders
LFH0642 VOICE TRACER ENGLESH USER MANUAL? REQUIRE
http://download.p4c.philips.com/files/l/lfh0642_27/lfh0642_27_dfu_aen.pdf
May 05, 2011 | Philips Digital Voice Tracer 2GB (2048 MB...
How do you turn it off? please...Philips MP3 player
Turn the MP3 player device on. The power button on most Philips MP3 players will be in the shape of a circle. The button will have a symbol that displays a circle with a slash through it. Hold this button down for approximately three seconds or until the MP3 player's screen begins to light up.
Power off your MP3 device. The same button that powers the device on will allow you to power it off as well. Press and hold the power button down until the screen goes blank. This will be your indication that the device is off.
Feb 28, 2011 | Philips Audio Players & Recorders
How to delete all files at once on Philips Voice Tracer 7655
You can download the manual for this machine at www.dictation.philips.com in the support section.
Mar 07, 2010 | Philips Digital Voice Tracer 7655
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Philips LFH0884/27 - Digital Voice Tracer 884 Digital Recorder, 8GB Logo
50 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
