Question about PfaFF Tiptronic 2040
Presser foot lifter won't work
The presser foot lifter won't lower the foot
4 Suggested Answers
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
bugoy31
  • 1238 Answers
SOURCE: Presser foot lifter is not
Good day norrishmi!!!
I am giving you an instruction manual.You will find the answer by clicking the link bellow:
http://www.sewingmachinesplus.com/media/products/Janome/sewist500/Sewist500_Instruction.pdf
Posted on Aug 15, 2011
  • 1564 Answers
SOURCE: Can't get my presser foot to fall down when I let go of the lifter on my Pfaff 6085 sewing machine
Sounds as if the spring for the presser bar is broken OR the presser bar is dirty and needs cleaned and oiled.
Posted on Feb 26, 2013
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Jun 20, 2015 | PfaFF Creative 7570
Presser foot lifter
foot pressure needs adjusting
Feb 10, 2014 | Bernina Sewing Machines
Feb 25, 2013 | PfaFF Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
Presser foot on bernina 180 won't go all the way down
Could be a number of things ... does the foot-lift lever go all the way down when you lower the foot and is it unusually 'floppy' when you lower it. There is a small spring inside that should keep tension on the lever and these can ping off if you inadvertently let the foot drop under its own pressure instead of letting it down slowly onto the fabric (they're a nightmare to put back, too !) ... if it has come off, it may be jammed in the foot lifter mechanism. It's also possible that the foot lifter has shifted on the foot bar, in which case it really needs to be looked-at by a qualified Bernina service agent. When raised, there should be a gap of 7.5mm between the bottom of the foot and the top of the stitch plate - if much more than this, it indicates that the adjuster has shifted and you'll need to get it looked-at professionally.
Oct 28, 2011 | Bernina Artista 180
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Jan 10, 2009 | Sewing Machines
Dec 31, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
27 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
