Question about Maytag ADE7005AYW Dryer
Makeing a squeling sound
Making load squeling sound, it does not always do it , it will work fine and then start or I can do a load and it won't do it all and some times it will do it from the start. thanks chris
    Top Expert:
  • Maytag Master
  • 34,193 Answers
Could be belt slippage due to wear.
Posted on Feb 12, 2014
I have a 1990 dodge dakota. Everytime I start my truck it makes a clicking noise and like a squel at the same time I don't know why it's making that sound.
Is the A/C on? Without more information it sounds like the compressor might be locking up and the clicking might be the A/C clutch engaging, the belt squeal will be the compressor trying to turn.
Jul 17, 2014 | Cars & Trucks
My 2009 c300 was fine all day now it won't start
batteries are prone to immediate failure from collapsing cells and it happens any time . Have a load test done on the battery to determine if that is the problem
Jul 17, 2013 | Cars & Trucks
Recently recharged ac but now it started squeling real load when I turn it on
When you recharged the unit you may have not put enough oil in with the freon.
Sep 03, 2012 | 1996 Plymouth Neon
My washing machine won't star
Thanks for choosing FixYa and welcome. If you have a washer that won't start, here are some probable causes to your problem. First, make sure to check your breaker box for a tripped breaker. If nothing is tripped, you will want to make sure the washer is getting power first. You need to check the wall outlet and the power cord. You can properly test both of them with a voltage meter to make sure they are getting correct power. Wiggle the cord and see if you can get it started. You could have a break or loose wire in the cord causing your washer to not start. If it starts, you still need to change out the power cord. If the outlet is not getting power, you will need to conduct a test on that to determine the cause. You may have a bad wire or a loose wire. If you have power to the outlet and cord, make sure your fuse has not blown. You need to check your timer switch next. It may be bad or not working properly. Refer to your manual for the correct procedure. Try the washer on different cycles to see if it will start. It is possible that you have a bad lid switch. It can cause the washer to not start if it is bad. You could have a defective motor as well. If the motor has not been working correctly or making noises and other sounds, there is a good chance it has finally died out. Always make sure that the part is getting power before you change it. A voltage meter is an ideal tool to keep around the house. If a part is not getting power, even with a new part, it will not work. Make sure you test everything before making a decision. Always determine the cause by testing and not guessing.
Jul 10, 2011 | Kenmore 24032\24036 Top Load Washer
The drum is not spinning during washing or rinsing
Idler pully is the usual problem. The two tub roller will usualy make knocking sounds but can make squeling nosis.
Jun 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
Apr 12, 2009 | 1997 Saab 900
Squeling noise in car when starting up and cold.
COULD POSSIBLY BE THE SERPINTINE BELT TRY SPRAYING SOME BELT SPRAY ON IT
Mar 31, 2009 | 1997 Toyota Tercel
Admiral clothes dryer making a squeling noise
The only thing that I know of that would cause a squeling noise from star to finish is the belt. Replace the belt and you will solve the problem.
Dec 15, 2008 | Dryers
Maytag ADE7005AYW Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
