Question about Staples ID Armor SH2836ID2836 Shredder
Wont turn on
I shut if off because it said to lubreicate but can't find out where to put the oil tried to turn it back on without doing anything and now it won't turn on
  • Maka Taufaga
    Maka Taufaga Feb 13, 2014
    something is caught between the blades, probably staple pins. you need an expert to open the equipment to remove this 'jam', then only will it operate again.
  • Staples Master
  • 1,087 Answers
If you can lift the cutting head up from the waste bin
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers and poke at any compressed paper wrapped around the blades - can take a while.
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Posted on Feb 28, 2014
Oil pan busted and then car shut down and wont start
Sounds like the engine seized from lack of oil. It only takes a minute without oil...
Apr 01, 2014 | Chevrolet Cobalt Cars & Trucks
My cell phone screen flickers when in a call and wont let me do anything
take out battery and sim card ,put battery back in without sim card turn phone on leave 5mins then take out battery without turning phone off put it back together turn phone on "just needs updated"
Jun 27, 2013 | Cell Phones
I think the headgasket is bad. it will turn over and everything but just wont start. i was push starting it for about 3 days because the alternator was going out. the last time i tried to drive it right as...
without a good look i dont think i could help as yes iam a europeon mechanic but a VW is a common enough vehicle here but iam thinking cam belt here but ?? yes it could be head gasket as the oil light switch is on the head top back left side and if the gasket has failed then it could be pumping oil into piston and not going up to the head to put the oil light out ,I would strongly advise you ask a local mechanic to put his head under the bonnet and give a second opinion from on the job .
Sep 26, 2011 | 1997 Volkswagen Jetta
Just changed oil on the 4200 watt Craftsman generator, motor starts and runs 2-3 minutes then automatically shuts off for no reason. Any ideas on how I can solve this problem?
make sure you put the correct type of oil in the crankcase for this machine
if you use the wrong type of oil ,oil level sensor float wont work and causes a shut down to protect the generator engine from damage
try draining oil and refilling with 20w/50 oil
cheers pauly46
Apr 03, 2011 | Craftsman Garden
My sansa fuze has frozen, and wont turn off, or go to any of my music, and wont play anything. how do i fix it?
Try to take battery out and put it back in again that would shut the hole thing down and restart it.sounds like you have a corrupt file on your player
Mar 24, 2010 | SanDisk Sansa e250 MP3 Player
1996 Subaru Legacy starts then shuts off immediately
ok ,im really not shure buthey ... look at the oil presure senssor or oil pump that coul be the problem if pump not good ...cant build pre4ssure enoughf then senssor turn the engine off ...thats why car will stay on wen you press gas...senssor could also be defected and give the same order to engine ...
wen you put switch on without starting engine ...wen all dash lignt go on ...you see oil lignt go on??????
Oct 30, 2009 | 1996 Subaru Legacy
Toyota celica shuts off, wont start
I hope it's your timing belt/ chain, and not a blown motor. They don't go far with no oil. The fact that it turns over is a good thing. Was there any oil left in it?
Jun 17, 2009 | 2002 Toyota Celica
E-machine 210 shut down and wouldnt come back on
try a different power supply first if this does not work
post here meage will go through other possibilities
May 21, 2008 | E-Machines eMachines Desktop PC
Tv wont turn on only clicks and then flashes red timer light
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Staples ID Armor SH2836ID2836 Shredder Logo
179 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
