Question about Sole Fitness F63 Treadmill
We removed the strap and it's sprung open & won't fold down.
How do seats fold down?
There might be a short strap in the center of each section where the back and the seat come together. Pull that strap to release and fold the seat aginst the front seat. Then you should seelatches to release the backs and fold them down. Hope this helps
Sep 25, 2014 | 2002 GMC Yukon Denali
Where exactly are the levers in the trunk of a
Open the trunk (UK: Boot). While looking at your rear speakers you will see there magnets sticking out of your rear deck lid (UK:Parcel shelf). In the middle of them will be 2 straps. These straps are what you pull to get the seats to fold down. give them a tug and the seats will go down, might be worth giving them a slight push if they havent' been folded down for a while.
Sep 19, 2014 | Cars & Trucks
Rear seat on my Note won't fold down. When I pull the handle up nothing happens. Any ideas?
Are we talking about Nissan Notes here? I have the same problem with my 2006 Note where the larger of the 2 split seats in the rear won't fold down. It doesn't have any side latches or boot straps and yanking it hard doesn't work either. I can't see any options other than complete removal of the whole rear seat assemby.
Aug 25, 2012 | Nissan Note Cars & Trucks
Can't open trunk using the inside lever, key or button. Any suggerstions as got perishable food stuck in there. Thanks
If your Grand Am has the split rear folding seat, you can try folding the seat down but using a wire coat hanger. Try to snake the coat hanger through the split in the seat and hook the strap to pull it to be able to fold the seat down to gain access to the trunk. http://www.gaownersclub.com/forum/attachment.php?attachmentid=17492&d=1121049659
As for the trunk being locked. Is it possible the remote lockout was activated? Try a yard stick to slide the red switch or just crawl in after you folded the seat down and removed all the food. If it's engaged, the remote solenoid will still activate (you can hear it), but the trunk won't open remotely.
Good luck and keep us posted. Thank you for using fixya
Sep 05, 2011 | 1999 Pontiac Grand Am GT
The straps which allow me to unlock latch to fold down the rear seats are missing. (I had the car detailed some time ago; seems they were not re-installed.) Is there any other way to get the rear seats...
Are you sure they weren't just tucked under the seat? check for the straps - if they are missing you can install a string or a shoelace in place of the strap, making sure to tie it securely to the little hook for the strap. Sometimes you'll need to use a pair of long nose pliers to pull on the strap mount to fold the seats down to give you room to work.
Nov 05, 2010 | 2000 Pontiac Grand Am GT
Does the back seat open to the trunk?
Go into the trunk. On each side, below the package shelf are two pull straps. Pull the strap for the side of the seat that you want to fold down. The one on the left is a 3/4 width seat folded down. The one on the right is a 1/4 wide seat folded down.
Aug 09, 2009 | 2003 Pontiac Grand Am
I cannot fold down seat
Try looking for a strap in your trunk it should be located at the upper inside of your trunk, there could be one or two straps, when you pull on these straps they act as a release lever for your rear seats, pull the straps toward you and push the seats forward from the trunk side.
Mar 11, 2009 | 2002 Oldsmobile Alero
I have a 1996 Isuzu Rodeo, and cannot seem to figure out how to lay down the back seats. Can anyone please tell me how to do this? Thanks, Jim Cummins: jcmusic@tampabay.rr.com.
There should be two seat belt clip notches in the seat where the seat belt clips comes out the seat. In those two notches there is also a strap in each notch that doesn't look like it really belongs there. Pull those two straps at the same time and the seat pops up and folds down. The back rest part of the seat will then fold down. Remove the head rest section of the back rest and it will fold all the way down.
Feb 22, 2009 | 1996 Isuzu Rodeo
Sole Fitness F63 Treadmill Logo
18 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
