Humphrey zeiss autorefractor 599
I had this linked to my EHR with a 232 cable, but now want to use printer . I can enable printer in "settings" but it just prints bars. I assume computer transfer still enabled somehow, but nothing I do seems to change it. There is a service password in settings, but I do not have it.
OzKluger
  • 27 Answers
SOURCE: How to create a security enable router?
Firstly, confirm that your ISP connection for email and internet is working correctly. Then connect the router to the ISP using the ADSL plug, and to your computer using the ethernet connection. It is best to set up your router using a wired connection to your computer. Once set up, you can connect your computer using WiFi. Have your ISP username and password handy.
There are two steps to secure your router:
1. Change your ADMIN password. Using a web browser like Intenet Explorer, type in the address, http://10.1.1.1. This should take you to a sign-on screen. Username is "admin", and password is set at the factory as "admin". You should now be logged in to your router. Go to the TOOLS tab, and change your admin password. NOTE THIS DOWN FOR FUTURE REFERENCE.
2. Secure the wireless part of the network: Go to the HOME tab, and select either WEP security (good) or WPA security (better, but some devices like printers don't like this).
For WEP you will need to enter a 10-digit WEP key. Numerals will do, or you can use hexadecimal (base 16) notation if you know this. Numerals will do and are no less secure. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
For the WPA alternative, you should select the "Pre-shared Key" radio button, and code in your WPA password in the "PSK String" field. This can be a word and or numerals. I don't think spaces or other characters are allowed. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
That's IT!! You've changed the admin password and secured the wireless part of the network.
You will then need to code the WEP or WPA password into the devices like printers and computers that you want to connect to the WiFi. For Vista computers, right click on the network icon in the tray (two little computers overlapping) and select "Connect to a network". Enter the WEP or WPA password when you see SSID "default" or your SSID if you've changed it. Most printers have a connection wizard.
There is a further enhancement if you are really paranoid: change the SSID and turn off the SSID broadcast. Go to the manual at:
ftp://files.dlink.com.au/products/DSL-G604T-GenII/Manuals/DSL-G604T_GenII_Manual_v1.11.pdf
if you want further details. Good luck with your secure network.
Posted on Jan 19, 2009
kvgopi
  • 73 Answers
SOURCE: How do I enable wpa encryption? I have an
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
Posted on Mar 26, 2009
SOURCE: when trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Posted on Jun 22, 2009
djuksoni
  • 103 Answers
SOURCE: How could i print pdf files with toshiba E-Studio 232
You need to buy GM1070 or GM1071,which are print enablers for es232.
Posted on Oct 29, 2009
  • 11 Answers
SOURCE: Laptop connects to wireless with Erthnet cable but
RE INSTALL THE LAN DRIVERS AND DISABLE THEWINDOWS FIREWALL
Posted on Feb 16, 2010
Battery low in Zeiss Humphrey Acuitus 5015 Autorefractor Keratometer, what can i do?
The batery is a integrated circuit that is soldered to the Mother Board. You should disolder that circuit in order to replace it
Mar 21, 2014 | Zeiss Humphrey Acuitus 5015 Autorefractor...
How to find the technical manual for autorefractor 5015 Zess
Hi Patricia where you from??Maybe i can help you.
marcelo
memoinstal@bol.com.br
Feb 19, 2014 | Zeiss Humphrey Acuitus 5015 Autorefractor...
Humphrey 599 auto refractor need to replace printer
The printer is termic, if it does not print well, vlean witj an alcohol and brushteeth and try again
Jan 20, 2014 | Zeiss Auto Refractor - Keratometer Carl...
Autorefractor Humphrey Zeiss Acuitus 5015 not sharpen the image
The problem is in the mainboard, look for j conectors, and try to see if any is released.They control the step motor who can make the camera focus
Aug 26, 2013 | Zeiss Humphrey Acuitus 5015 Autorefractor...
Zeiss 5015
Hi Mariela where you from, maybe i can help you.
Mar 18, 2013 | Zeiss Humphrey Acuitus 5015 Autorefractor...
White screen beep
The battery can be seen circled in green in the photo below. It typically has a 10 year life. All apologies for the repeat text/ newbie here.d3d64cf2-75ae-495a-bf4e-dbcf5ee471c9.jpg
Jan 19, 2013 | Zeiss Humphrey Acuitus 5015 Autorefractor...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
