Question about DeLonghi Heating & Cooling
Delonghi F1 error - DeLonghi Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
DeLonghi Alicia EMK6 - H20 error
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Jul 30, 2007 | DeLonghi Alicia EMK6 Coffee Maker
Press clean button error message on delonghi ESAM 5500
Hi Susanah
my deLonghi also wants a clean now and then. In your situation I Would disconnect the machine, wait awhile then connect again and see if she still wants a bath or it is an error .
good luck
kolbrun
ps there is always the troubleshooting page in the manual,
Aug 12, 2015 | DeLonghi ESAM5500
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Error e6 displaying on single split model one inverter 12k
I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication malfunction. So can you tell me how can I fix it
Apr 05, 2010 | DeLonghi CF210 Portable Air Conditioner
What does F1 fault code mean?
Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
Jan 08, 2010 | Kitchen Ranges
Delonghi Dehumidifier E! error
I Had an E error (not an E1 error) when I was fiddling with my humidity/temp sensor on the face of the radiator fins (behind air filter).  The sensor was WET.  I dabbed it dry, let it sit all day, and re-assembled.  It works fine now.
Aug 30, 2007 | DeLonghi DE500 Dehumidifier
Heating & Cooling Logo
105 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
