Question about IBM System x3250 M3 4252 - Server - rack-mountable - 1U - 1-way - 1 x Xeon X3450 / 2.67 GHz - RAM 2 ... (425252U)
IBM Server not detecting hard drives
I have a system X3250, due to a UPS failure during a power outage, the server lost power and would not come back up. (Wouldnt power on) Contractor checked and advised that the motherboard was fried, so had that replaced, next contractor called and advised that the raid card was dead - replaced that. Now contractor saying that the hard drives are still not picking up. Because this server had critical data, I swapped the hard drives from a working server with the hard drives on this one before sending to contractor so I know for a fact the hard drives are fine.. What else should I look at / get them to look at.
  • 508 Answers
You know i find this all very suspicious. For one thing a ups is designed to take the hit so it will get fried and your computer will be fine. Suspicious to me but not an answer to your question so i will try this. The new raid card was installed (might be off on this part, haven't kept up with this) were the hard drives and the raid assembly matched back up. IE raid 1, 2, 3 etc. Do believe they are up to raid 7 now. So if hard drives were not put back in the original position and and raid card setup for the original raid array you might have this problem. Hope this helps, but it's been a long time since i worked with raid arrays.
Posted on Mar 30, 2014
enuro12
  • 116 Answers
SOURCE: raid w/ hard drive defunct
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Posted on Oct 10, 2007
  • 13 Answers
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Posted on Nov 26, 2008
falsafat
  • 31 Answers
SOURCE: hard disk no detect in installtion of window
You need to give windows installation the drivers for your Sata-Bus by pressing F6 while the installation load the drivers (like when we want to install on RAID drive). or do the following method follow the links in that page for Slipstreaming VIA Serial ATA drivers and the other link to create a boot CD Creating a bootable Windows CD with Nero.
it's all in the following link: http://weblogs.asp.net/jkey/archive/2005/08/28/423901.aspx
Posted on Apr 12, 2009
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
  • 105 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
TG 9201 IS UNPLUGGED
Does this phone system have a central server? If so I would go check to see that it has power and came back up after the power outage. A lot of phone servers are on a battery backup and when the power goes out the software tells the server to shut down and then the UPS powers off.
Mar 17, 2014 | Inter-Tel Axxess Corded Phone
Battery Back-Up not coming back on after power outage. Charged for several days without anything plugged in with trip button pushed in. Surge side still working. No beep light or anything on battery...
Does the unit have a breaker on the back? There may also be a fuse. You should be able to find a users guide on the CyberPower website.
If the unit may have failed during the power outage.
Jan 07, 2013 | CyberPower Computers & Internet
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
Why is it our computer server keeps on rebooting or ups can't properly function during black out?
Without further information as to the exact symptoms, it is important to point out that UPSs are only meant to function for a short amount of time (between 3 and 30 minutes, depending on model). The UPS will simply run out of battery power after that time. If the UPS has a computer interface, it may instruct the server to shut down when primary power is lost to prevent data destruction.
If the UPS does not function even briefly during a power outage, the batteries have liken gone dead and either they or the entire unit will need to be replaced. Another possibility is that you do not have a UPS at all, but a surge protector or other device that does not supply power at all.
Oct 21, 2010 | Computers & Internet
Uninterruptible Power Supply problems. My uninterruptible power supply (UPS) is not backing up during a utility power outage.
First, we do need to full charge it. Then see what's being able to pick up a load of this Ups power or not? If not then it means something is wrong with this Ups. Please put this change.
Jun 30, 2010 | Powerware 9120 UPS System
Yesterday and today one of our Smart-UPS 1400 powered off and 2 of our servers along with it. What would cause this?
may be power to the UPS went off or was not within permissible limits, hence the ups run on batteries until they were completely discharged, the servers went off because they are supplied by this ups. check the power supply to this ups, somebody could be switching it off accidentally. try to sitch the inpu power to the ups to see whether the batteries are okey
Dec 15, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
What problems do these technologies solve in UPS?
1. Provide conditioned clean AC power to computers & other peripherals (except laser printers, which should not be powered by UPS).
2. Protect equipment from the harmful effects of brownouts & sags.
3. Supply power to equipment during a power outage for a specific time, either to allow for the graceful shut down of systems, or to keep the systems working during the power outage (depending on the battery capacity).
Jul 17, 2009 | Fenton Technologies Computers & Internet
Ups troubles
What is happening here is you are transferring load to battery during a power outage but on return of Line Power the UPS is not smoothly transferring back to Normal mode. As a result you are basically turning off your computer. Two options... shut down your computer orderly during an outage or buy a new UPS.
DD
Dynamic Power Solutions LLC
Aug 20, 2008 | Computers & Internet
IBM System x3250 M3 4252 - Server - rack-mountable - 1U - 1-way - 1 x Xeon X3450 / 2.67 GHz - RAM 2 ... (425252U) Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
