Question about Weber Q Grill
I have a Weber 220 that just quit on me. Over a couple months, I bought and replaced new burner, new regulator, new hose, and new propane tank, but it still doesn't work. Gas flow seems to be a prob
Over a couple months, I bought and replaced new burner, new regulator, new hose, and new propane tank, but it still doesn't work. Gas flow seems to be a problem as it doesn't pump out enough propane. That's all a grill has, what else could go wrong?
You may have a blocked/partially blocked gas injector which is a jet supplying gas to the burner.
Posted on Feb 16, 2014
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: have a type 6980 gas regulator not getting enough gas to the burner
Hi leonard4538
Regulators are notorious for doing just what yours is doing.
After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow.
Remove the regulator if possible, if not try it in place with the tank removed.
Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside.
After tapping and freeing the regulator diaphram reinstall and you will be good to go.
If this does not work, the replace the regulator as it is defective.
Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located.
Please take time to rate me
Bud
Posted on Oct 27, 2012
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
I have a brand new , full tank of propane. I cannot get the propane from the tank to the burners. I am not sure if Ihave a bad hose and regulator or a bad valve that will nto allow the propane to flow...
Julian, let's get this corrected for your 4th of July Cookout.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Jul 04, 2011 | Weber Genesis E-310 Gas Grill
Bought a weber genesis 320 Problem with the Weber Genesis E-320 Propane Grill bought a weber genesis 320 in US and need to replace the hose / regulator that it fits to German LP gas cylinders. Which...
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
May 08, 2011 | Weber Genesis E-320 Propane Grill
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
My Weber Genesis Silver only lights on the first burner. The second and third burner are not lighting.
Close the propane tank valve and disconnect the hose/regulator from the tank. Reconnect the propane tank and very slowly open the tank valve. You may have opened the valve too fast causing the built-in excess flow to close to a trickle. If you still have issues, let me know and I'll dig deeper. Douglas
Oct 08, 2010 | Weber Genesis Silver A Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
May 18, 2009 | Weber Baby Q Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Q Grill Logo
314 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
