Question about Sportsart 6300 Treadmill
Sportsart 3106 spark at switch
When plugging in the treadmill there is a spark at the power switch, may run sometimes then powers down
Bamix dealers vancouver bc
This could be a bad elevation motor, but could also just be the nylon gears inside the lift motor. I am attaching two links. One is to the service manual and the other is to the parts for this model. This should help you get to the bottom of this and get it fixed. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
SportsArt Treadmill 3200 Parts Overlay Nylon Gear Fuse SPORTSMITH net
Apr 29, 2014 | Sportsart Exercise & Fitness
Sportsart 1080 treadmill error 01
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Mar 17, 2014 | Proform Power 1080
SportsArt 6300 error display 04 -0015 help...
the power supply is receiving too low or higher currents.You must test this. Or you need to call the service tech. However try to RUN the s. calibration if you can. Otherwise reset the machine. and see the block diagrams attached.
God bless you
Dec 05, 2012 | Sportsart 6300 Treadmill
Sportsart 1080hr has power, but only red emergency stop lights are flashing. Magnetic key in place. Nothing happens if I reset the emrg stop?
1) adjust the REED switch, test for open or defective, clean it, and tight the plug or connector very well.
2) After you fixed RUN the software calibration for easy diagnose, troubleshooting. and fix it.
God bless you
Nov 28, 2012 | Sportsart 6300 Treadmill
My sports art 1060 when give it power the screen power on but not work
1) adjust the Reed switch, clean, and tight the connector very well.see the diagram attached.
2) Tight the ribbon cable from keypads, very well, and clean.
3) Tight the connectors from display board vs lower board.
See the diagrams. God bless you
Jun 02, 2012 | Sportsart 6300 Treadmill
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
15A fuse going out. Replaced 3 with no success, spark on low end of board after about 5 seconds, thenn fuse went.. Unplugged power wires to the lower board, powered up treadmill and the fuse survived. ...
You are going to need a motor controller, or find someone who can repair the one you've got there.
If it blows the fuse immediately on power up, it may require a full wave bridge rectifier replaced on the controller. If it blows when the start button is pushed, it might be a MOSFET or SCR found on the motor controller..
Sportsart fitness can be reached by phoning 1-866-709-1750. The website is found at
http://www.sportsartamerica.com There you can find a dealer/service depot in your area.
Dec 19, 2010 | Sportsart 6300 Treadmill
Sportsart 3200 Treadmill Belt motor problem
5v DC equals .5 mph every 10v equates to 1 mph try increasing the speed if the DC voltage increases that means the motor control is working properly, then go back to the drive motor and check the motor brushes even though you have used a DC power source. They sometimes will not seat correctly and cause no belt movement, use a commutator stone a clean up the commutator arm.
May 26, 2010 | Exercise & Fitness
Sportsart 6300 Treadmill Logo
24 people viewed this question
Top Sportsart Exercise & Fitness Experts
Steven's...
Steven's...
L Pfaff
L Pfaff
Tom Chichester
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
