Question about Boating
Wieght of 1988 chettah 21 ft daycrusier 3.7 l
How do I convert 420 sq ft to linear feet?
It depends on the width of the building. Example: If the building is 10 feet wide (10 ft wide x 42 linear ft = 420 sq ft) or (420 sq ft divided by 10 ft wide = 42 linear ft.) the linear feet is 42. If the building is 20 feet wide (20 ft wide x 21 ft wide = 420 sq ft) or (420 sq ft divided by 20 ft wide = 21 linear ft.) the linear feet is 21.
Jun 21, 2017 | Linear Office Equipment & Supplies
What is the width od a whirlpool fridge model number ET20DK
Hi Dennis:
Looks like the hermit answered this a while back.
hermit58
  • 33 Answers
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Jul 08, 2015 | Whirlpool Refrigerators
How much n- m must i torque my nissan sentra 1400 gxi cylinder head
1.8L 4 cylinder
cylinder head bolt torque
bolts 1-10 ( large bolts )
step 1 21 ft lbs.
step 2 44 ft lbs.
step 3 loosen all bolts
step 4 21 ft lbs.
step 5 additional 50-55 degrees
bolts 11-15 small bolts
56-74 in. lbs
2.0L 4 cylinder
step 1 29 ft lbs.
step 2 58 ft lbs.
step 4 23-25 ft lbs.
step 5 additional 90-95 degrees
step 6 additional 90-95 degrees
Apr 30, 2011 | 2000 Nissan Sentra
Serptine belt diagram
Belt Installation, Aerostar 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 N606068 Bolt 3 10300 Generator 4 10153 Generator Mounting Bracket 5 8509 Water Pump Pulley 6 6B209 Drive Belt Tensioner 7 N800199 Screw 8 8678 Belt Idler Pulley 9 N802096 Screw 10 19703 A/C Compressor 11 2882 A/C Compressor Mounting Bracket 12 3C718 Brace 13 N806020 Bolt 14 3A674 Power Steering Pump 15 3A733 Power Steering Pump Pulley 16 N800199 Screw 17 N606572 Bolt 18 N620481 Nut 19 8501 Water Pump 20 6312 Crankshaft Pulley A - Belt Tension Check (See Specifications) B - Tighten to 40-55 Nm
(30-41 Lb-Ft) C - Tighten to 24-30 Nm
(18-23 Lb-Ft) D - Tighten to 21-29 Nm
(15-21 Lb-Ft) E - Tighten to 40-50 Nm
(30-37 Lb-Ft)
Belt Installation, Ranger and Explorer 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator 3 8678 Belt Idler Pulley 4 19703 A/C Compressor 5 3A733 Power Steering Pump Pulley 6 8501 Water Pump 7 6312 Crankshaft Pulley 8 6B209 Drive Belt Tensioner 9 N806020 Bolt 10 2882 A/C Compressor Mounting Bracket 11 3A674 Power Steering Pump 12 N606572-S2 Bolt 13 N800199-S8M Bolt 14 N620481-S2 Nut 15 3C718 Brace 16 N606068 Bolt 17 10153 Generator Mounting Bracket 18 8509 Water Pump Pulley 19 N605805-S2 Bolt A - Belt Tension Check (See Specifications) B - Tighten to 21-29 Nm
(15-21 Lb-Ft) C - Tighten to 40-55 Nm
(30-41 Lb-Ft)
Belt Installation, Ranger 2.3L Engine
Item Part Number Description 1 8678 Belt Idler Pulley 2 10300 Generator 3 8509 Water Pump Pulley 4 3A733 Power Steering Pump Pulley 5 2E884 A/C Clutch Pulley 6 6312 Crankshaft Pulley
Belt Installation, Aerostar 3.0L Engine
Item Part Number Description 1 10300 Generator 2 3F671 Belt Idler Pulley 3 3A733 Power Steering Pump Pulley 4 6B209 Drive Belt Tensioner 5 6312 Crankshaft Pulley 6 8509 Water Pump Pulley 7 19703 A/C Compressor 2010&c18=modelyear&c35=wsm%2cdrive%20belt%20replacement%2cssk%2c03-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1995 Ford Aerostar
Need torque sequence and specs for cylinder heads on a 1988 olds cutlass cierra with a 2.5 liter 4 cylinder engine
WELL ..THE FINAL PASS ON IT IS 65 FT LBS
YOU WANT TO DO THREE PASSES OF EQUAL INCREMENT'S LEADING TO 65 FT LBS
STARTING FROM THE CENTER TWO BOLTS AND WORKING YOUR WAY OUT IN A CROSS
SO BASICALLY THE FIRST PASS WOULD BE 21 FT LB.THE SECOND PASS WOULD BE ROUGHLY 43 LBS THEN THE FINAL PASS OF 65 FT LBS.
Dec 26, 2010 | 1988 Oldsmobile Cutlass Ciera
I do not know how to remove front seat from a 1994 chevrolet beretta cp
hmm,, ok,, try this..
1.) look under the seat you will notice two sliding rods,, on this there are 4 brackets with bolts.. its maybe hidden under the upholestry,, any way remove the bolts,, slide any lift seat..
Oct 12, 2010 | Chevrolet Beretta Cars & Trucks
WHAT IS CYLINDER HEAD BOLT TORQUE ON A 1988 JEEP CHEROKEE LTD. 4.0?
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side.
Oct 07, 2010 | 1988 Jeep Cherokee
I have 4.9L6 need torque specs for cylinder head
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
Dec 05, 2009 | 1988 Ford F 150
Head bolt torque settings
8mm nut= 16.5 to19.5 lb/ft
9mm nut =21 to 24 lb/ft..
Sep 24, 2009 | 1988 Suzuki LS 650 Savage
Can you give me the measurements height width depth of the KTRC19KK?
STANDARD MODELS
INTEGRATED MODELS
Jul 07, 2009 | Refrigerators
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
