Question about Makita Tools & Hardware - Others
Plugmy 18.4 lithium battery into charger and red and green lights flash and beep
18.4 lithium cordless drill
SOURCE: Battery Issues
When Li-Ion batteries are discharged to a too low voltage (below 2,75 V/cell, in this case 13,75V) the charger will assume that the battery is damaged, and will not charge the battery. First measure the battery voltage with a volt meter, if the voltage is significally below the 13 V the battery are no good. If you have a reading of lets say around 10 V, you can raise the voltage shortly on the battery, by jumping it with a fully charged battery. Connect the "-" poles on each battery. After this, shortly connect the "+" poles, for no more than 5 seconds,disconnect the wires and immediatly put the battery in question in the charger. If it starts charging, every thing if fine. If not, try the process again, you might wanna recheck the voltage if it rises.
Please be aware, that over discharging Li-Ion batteries, will lead to damage of the Li-Ion cells, which results in loss in capacity, therefore, if you are not to use your Li-Ion tools for a while, make sure the batteries are fully charged.
Hope you guys could have sucess with the above
Best regards
Soeren
Posted on Jun 28, 2008
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
Posted on Feb 18, 2009
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
  • 11 Answers
SOURCE: I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Posted on Apr 17, 2010
  • 2428 Answers
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Posted on Jan 16, 2011
New battery when put on charger blinks red and green light
that indicates the battery has failed ,sadly and unless than 1 year old it is junk. Batteriesplus will not repair them.
Jan 22, 2015 | Makita BFR750 18-Volt LXT Lithium-Ion...
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
What does it mean if the red and green light are on at the same time on the charger
If the red and green lights are flashing, the charger is detecting the battey has a defect and is not safe to charge. It could be one of the cells in the battey, a short in the wiring or circuit board or bad contacts. Usually the only fix is to replace the battery.
Jun 26, 2012 | Makita 18V LXT Lithium - Ion Cordless...
Green flashing light
battery is open circuit or charger not working Re: Jeff
Apr 07, 2012 | Makita 18V LXT Lithium - Ion Cordless...
I am having problems with my 18v porter cable cordless drill. I have had it for two year and have rarely used it. Only used one battery. Now I am unable to charge either of the batteries. They are lithium....
Do not try to repait the battery. There is a possibility you could fix it but don't try it. Acid is not friendly on humans body.
go out and buy new batteries for it. I would suggest you buy the type of battery it came with.
One more thing; Make sure you remove the battery and store it in a normal temperature area anytime it is not in use.
Please rate if this helped you.
Apr 17, 2011 | Porter Cable-Cable PCL180DK-2 18-Volt...
Hi both red and green lights are flashing and it wont charge battery bl1830 lith ion
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Sep 13, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Tools & Hardware - Others Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
