Question about Digi-Tech Music
Left pedal isent working - Digi-Tech Music
  • 21 Answers
U ll need to replace the micro switch .
Posted on Feb 13, 2014
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
I have a Digitech wammy 4 v pedal the led light are going out i have 3 lights left how can i fix the led light the pedal works fine with out the lights
Check the burned out LEDS with a 3 volt battery- a computer bios battery works well for these.
If they do not light, which is likely, just replace them with similar sized units. You can even change their color too. Measure the voltage at the LED sodler pads to see if it is more than 3 volts, if it is, add a resistor to drop the voltage and limit current to the replacements. Digikey sells them, and they ship around the world http://www.digikey.com or Mouser, Both are based in the US, I am not sure what Mouser's international shipping is. http://www.mouser.com
If there is no voltage at the LED pads, look for bad solder connections, or burned out resistors. If the few remaining LEDs still operate as they should, the level meter chip "should" be okay.
Feb 14, 2012 | Digi-Tech Music
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hello the cables say R-C-L, and my RD-700GX ports are damper, FC1 and FC2, which cable to which port, thank you.
R-C-L stand for right, center, left... On a standard piano, the RIGHT or "R" pedal is the "damper".
The other pedals are the soft and sostenuto The "Soft" is the LEFT pedal and the Sostenuto the center. The FC controller inputs can usually be configured by the user so you need to read in your user manual how to set those and connect whichever cable to the appropriate FC input.
Jun 25, 2011 | Roland RPU3 Pedal Unit for RD700NX
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Feb 28, 2011 | Roland DP-10 Damper Pedal, B-Stock
Hi, I recently had this bass effects pedal worked on. unfortunately, the technician clipped off the wires from the expression pedal to the board, so, now, the pedal doesn't do anything. I need to rewire...
Who knows what brand pedal you have... and there are many. The schematics for these are USUALLY not available... however, usually one can use their head and effect a repair.
FIRST, it is unlikely if you have three clipped wires that you can do much damage by connecting them wrong to the three terminals of the expression potentiometer... there are ONLY six ways to connect the leads. If the pot goes into a digital signal processing thing there is a chance that it is really a voltage divider of a voltage reference and we COULD possibly damage the pot in that case... so let's be smarter:
Where the leads attach to the circuit baord are LIKELY in a pattern of three pads in a row and you should have witness marks of where the leads were clipped... by the way, fire that technician...
Usually the center pad will go to the center of the pot leads... Then you only have two left... get them backwards and the pedal will be backwards so you can just swap them. Try this method and see if it works... If you haven't fired the tech yet, don't forget to...
Feb 12, 2011 | Music
LEFT DAMPER PEDAL DOES'T WORK
For a damaged cord, just buy a cord wot correct plugs on it and open pedal and replace the cord. There are usually only two wires to worry about.
Dec 09, 2009 | Music
Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Mar 12, 2009 | Yamaha Music
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Music Logo
19 people viewed this question
Top Digi-Tech Music Experts
rjivaro
Ben Armstrong
Are you a Digi-Tech Music Expert? Answer questions, earn points and help others
