Question about Prolectrix Balmoral Electric Fireplace Heater w/
Prolectrix fireplace fuse - Prolectrix Balmoral Electric Fireplace Heater w/
How to make ice cream?
You want to make ice cream with a fireplace? Interesting.
Jul 30, 2014 | Unknown ProLectrix 80-4998 Windsor Wall or...
I have a prolectrix wall mounted bowed fireplace model BG-D4. The fan quit working and now it overheats and shuts down. Is there a fuse or a reset button?
I don't know this specific product but if it is designed to run with the fan, it will overheat if the fan stops and shut down. Often, the shut down is by a thermal cutout, so just wait for it to cool dow.. You may have to remove power.
Jun 23, 2014 | Heating & Cooling
The plug on the fireplace keeps burning out. I had the fireplacefor about 4 yearsa and had to replace the cord as well asthe receptacle or our house would have burnt down, We don't want to change it...
Hi Dave
I suggest you have the fireplace checked out.
Check the power rating of the fireplace, the power rating of the power connection, and the power rating of the fuse your house has for this unit. The fuse should be rated a little higher than the fireplace, and this should trip before the plug starts to heat up. It should not burn out.
There may be a short circuit, or the heating element in the fireplace may be faulty.
Get a professional to do this as you and your families safety is most important.
Feb 02, 2014 | Ovens
Prolectrix 7 stitch sewing machine Instructions
This is a toy really, so if it did not come with a manual, suggest you ask where you bought it...but it may never have had one, there seems no reference to them anywhere I can see.
Oct 20, 2011 | Sewing Machines
I have a fireplace purchased from home depot. We had a power outage and the pole outside had a fuse blown from a major storm. The fireplace never came on after power was restored 3 days later. I dont...
If you still have the owners manual it should tell you the location of any resets,fuseible links,or fuses.I think from a storm of that intensity that if you are lucky it just tripped the reset. I also would double check all breakers and fuses. Before I spent the money on a new one I would verify that you have power to fireplace.Any decent electrician should be able to check this for a minimum charge. I hope this is some help. Thanks
Nov 24, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Machine sews without touching pedal
I found the full Prolectrix 8 Stitch manual with google+ here.
Find it listed in the result pages.
Hope that helps!
Apr 30, 2009 | Sewing Machines
Problems with prolectrix sewin machine
you have to make sure the bobbin thread is positioned right in the middle. When the needle comes down (into the bobbin compartment), you can peer into the bobbin compartment and see a loop of thread (coming out of the needle). You want to catch that bobbin (thread) in the loop of thread (that runs from the needle).
Feb 15, 2009 | Sewing Machines
Prolectrix Balmoral Electric Fireplace Heater w/ Logo
46 people viewed this question
Top Prolectrix Home Experts
john h
Tom Chichester
Are you a Prolectrix Home Expert? Answer questions, earn points and help others
