Question about Sanyo R227 WiFi FM Radio
No wireless not picking up any stations
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
Oregon Scientific WMR86A wind sensor does not communicate to the base station. It is a new device, first time assembled.
I believe the wind sensor is a rotating cuff that has a wire which needs to input into the main reader or the wifi unit.if it's the wifi unit you need to check the receiver is picking up the signal.if it's the main readout then check the connection.if it is wireless, you may find a switch on the transmitter to change channel.this may fix the problem, especially if the receiver is near other wireless or bluetooth equipment.
Feb 19, 2015 | Oregon Scientific WMR86A Backyard Pro...
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
Need antenna for avr 235 that will pick up stations
Check your current antenna connection to be sure it is OK. If your receiver has a scan function, try it to see whether it detects any stations
Jan 19, 2013 | Harman Kardon AVR 235 Receiver
Poor connection strength
Sometimes you will get a false low signal strength indication, but here's something to try anyways.
Imagine if we lived in a society where all TV signals came in on the same channels.
If you are watching channel 11, but 3 other tv stations are broadcasting along with the one you want to watch, it takes a lot more effort to get the information you want from the one station you are trying to watch.
So lets say you and your tv station strike up a deal, and they move to channel 6...and nobody else in the area is on channel 6...great, now you can watch your program effortlessly.
Wireless can be like that, and most routers are factory configured to channel 11.
Look in your router manual or pdf guide or whatever instructions you have for it, and change the wireless channel.
I have found in the past that you can go from poor signal with frequent disconnects, to full signal strength at the highest speed and no disconnects, just by choosing a better channel (and yes, I usually pick 6 first, and only try others if necessary).
Feb 27, 2011 | NetGear WPN111 RangeMax Wireless USB 2.0...
My wireless adapter cannot detect any wireless network
Wireless adapters come with an installation disc.Uninstall the wireless adapter and then reinstall it,this should start the ball rolling,but some wireless adapters must use a wireless router plugged in to the main phone socket via the filter RJ11 PLUG,OR RJ45(A SLIGHTLY BIGGER PLUG)WHEN YOU SET THIS UP THE ADAPTER WILL PICK UP THE DATA FROM THE ROUTER,AND YOUR ON THE INTERNET.WIRELESS ADAPTERS WON'T RECEIVE ON THEIR OWN UNLESS YOUR NEAR A PICKUP STATION LIKE AN INTERNET CAFE OR A RAILWAY STATION.Go to an electronics shop like MAPLINS,and buy a wireless station detector.Then you will have to pay about from .99p to log on to a wireless cell..99p will give you about an hour on the net.GOOD HUNTING.
Aug 09, 2010 | IBM Intel PRO/Wireless 2100 MiniPCI...
Why does my wireless internet only work when the network is not locked? does this mean my internet is not secure?
By not "locked" I assume you mean with security enabled. All clients connecting to your wireless access device must use the same credentials for security as your access device. Otherwise your clients will pick up and connect to any network that is unsecure.
Jul 06, 2009 | Apple AirPort Express Base Station with...
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
Cannot connect to the internet on Belkin Wireless G USB
I had a similar problem and solved it this way: Go to Start > All Programs > (the name of your USB adapter). In that folder there should be a "manager" or some type of program. Run it. One of the settings should read "AP mode" or "Station mode". When I switched from AP to Station, suddenly a list of available networks popped up. And my problem was solved. Hopefully that will work for you too. GregM23
Jan 12, 2009 | Gateway (802.11usb) Wireless Adapter
When trying to go online with mx vs. atv untamed, it says the latest software has been found and click ok to download. Once we click ok, it downloads about 4-10% and then an error comes up!!
Is it your internet wireless router? do you have a strong signal? If you are connected to someone else wifi that you are picking up it is probably a weak connection. I can pick up my neibhors wireless signal and connect to it for play station shop, and the internet, but when i update the signal is too weak to do it.
Dec 30, 2008 | THQ MX Vs. ATV Untamed
Sanyo R227 WiFi FM Radio Logo
82 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
