Question about NBC Universal CNBC Real-Time
Doesn't show stock quotes at all
Usually when it has to hit reload you can hit retry and it loads the live quotes after a try or 2. retry stopped working today just after 4pm and so I updated the app. new version is horrible and still doesn't show any live quotes. totally borked. how do we get the previous version back and actually showing live quotes including for afterhours?
Can't boot,showing "no bootable device,hit any key
Take it to an IT specialist as I suspect the hard drive may be dead.
May 19, 2013 | Computers & Internet
Lg phone shows time and date but will only make emergency calls. says to retry
Download and install lg phone drivers and the LG updater.
Now connect the phone to PC with a USB cable.
And launch the LG updater. This will fix your problem.
If not let me know. I'll give a next solution.
Cheers...!!!
Nov 29, 2012 | LG Quantum Smartphone AT&T C900 Windows 7...
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Screen doesn't show when plugged up
Try performing a soft reset by pressing and holding down the power button for at least 10 seconds until it restarts.
You may also want to run the Garmin WebUpdater to load or reload the current software as this can usually fix any issues.
http://www8.garmin.com/products/webupdater/
You can also call Garmin Support for assistance.
1-800-800-1020
Jan 09, 2012 | Garmin Nuvi 1200, Nuvi 1210, Nuvi 1240,...
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
NBC Universal CNBC Real-Time Logo
47 people viewed this question
Top NBC Universal Apps Experts
Erin Wood
Erin Wood
Are you a NBC Universal App Expert? Answer questions, earn points and help others
