Question about GE Refrigerators
GE Monogram built-in loses gas within 2 days
Have a GE ZISS48NCSS refrigerator bought 12 years ago. The first 6 years have been trouble free and then it goes out every six months. Changed capacitor, compressor, added gas, added extra fan for cooling, etc. The latest episode we put in more gas which lasted two days and stopped working. What can I do to fix it?
  • GE Master
  • 4,655 Answers
You need to find out where the leak is located to repair otherwise if you continue to charge with Freon the fridge is going to get moisture inside the sealed system. A lot of times the evaporator will leak causing moisture to be pulled in. The leak could also be in the condenser coils or the yoder loop.Can you charge it again and use soapy water to help you to locate the leak? Are you equipped to repair the refrigerator? Thanks John Tripp Sea Breeze
Posted on Feb 12, 2014
  • John Tripp
    John Tripp Feb 13, 2014
    Sometimes I am curious to if anyone really sees these post. Did you see my post N Shyamprasad?
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 184 Answers
SOURCE: GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Posted on Apr 08, 2008
SOURCE: GE Refrigerator Compressor Inop.
I found this post by searching on the capacitor number, JSU21X126AQC. My 2001 Kenmore refrigerator (don't have model# here) compressor didn't run, but I heard it hum for a few seconds and then a click. That's the Klixon overload doing its job. I measured resistance of the compressor leads same as original poster. This lead me to determine that the windings were not open or shorted. The wiring to the compressor also fed the condenser fan, and it was running, so power was at least all the way to the compressor.
What I did find was that the 12uF capacitor was only 4uF. My digital volt meter has a capacitor check range. This compressor circuit is a permanent split capacitor type. Without the proper capacitance, the compressor can't start. I replaced it with a 10uF, 220v AC capacitor I had, and now it runs fine. I wonder how many refrigerators are scrapped because of this inexpensive problem?
Posted on Jan 07, 2009
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
GE Monogram built refrigerator defrost problem
What to do? It has been in service more or less for 12 years, way past time to replace.
Mar 03, 2017 | Refrigerators
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
www.geappliances.com/ge/find-model-serial-number/
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance
products.geappliances.com/appliance/gea-support-search-content?contentId=16195 How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances
www.geappliances.ca/en/products/discontinued-models Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - AppliancePartsPros.com
www.appliancepartspros.com > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
http://www.appliancepartspros.com/parts-for-ge-zdp48l4gh3ss.html
These are posts about that Range
https://cse.google.com/cse?cx=partner-pub-9933858514302629:4836214790&q=ZDP48L4GH3SS&oq=ZDP48L4GH3SS&gs_l=partner-generic.3...146736.146736.0.147883.1.1.0.0.0.0.115.115.0j1.1.0.gsnos%2Cn%3D13...0.42j1764j2..1ac.1.25.partner-generic..1.0.0.BUEnm5lSMk4#gsc.tab=0&gsc.q=ZDP48L4GH3SS&gsc.page=1
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
My GE monogram built in refrigerator is not staying cold
GE Mono frig are built with shut off senser on the compressor. Wipe the condenser coil with damp cloth. This will resolve the problem. This lession cost me $160.00 from GE frig tech guy. Not to mentioned using my clean cloth and wiped for just 5 minutes.
Nov 07, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
